Z1 fuel cock
- jzanutto
just want to see if anyone has used these....
1978 KZ650B 2004 BMW R1150RT
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- jzanutto
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Iron Duke
- what are you rebelling against?
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- KOOL RYDER
- KZ 650B2 / KZ 1000E
Can someone explain to me the difference between the vaccume and the manual petcock?
On my 650 B2 the vaccume hose connects to the carbs, I am assuming that this hose is eliminated when using the manual.
SO - do you need to block off the hole where the old vaccume tube used to go?
ThnX
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
- Thank you received: 2098
Hey Guys,
ThnX
Vacuum petcock is designed to be always OFF (in either PRI or RES position) until actuated by receiving vacuum from a running engine. Eliminates need to remember physically (manually) turning it OFF when the engine is shut down. Manual petcock has three positions, which are ON, OFF and REServe.
Converting from vacuum to manual eliminates the vacuum hose, at which time the vacuum nipple at the carb should be capped off where the hose previously attached.
FYI -- manual's ON (and RES) are same through fuel flow as vacuum's PRIme.
Good Luck!
- RonKZ650
- Thank you received: 240
...The diaphram...will fix most problems.
Z1E lists the vacuum petcock diaphram for $12.46
and the full vacuum petcock kit for $22.49
Good Luck!
- wiredgeorge
- eaglecrash2
ya me 2, i always replace the vacume ones with the manual petcocks, mutch less hassle.
I just installed a pingel manual shutoff on my '77 650 and even in the shutoff position there is still a puddle of fuel under the bike the next day. Still the same old problem. Maybe I should have nought the expensive model?
'77 kz650,'06 Vulcan 500ltd, '07 ducati 1098s, '03 bmw m3, '85 carrera, '71 911s, '06 s2000, '03 suburban, '76 triumph TR6
sold: '69 honda 250, yr(?) 50cc honda moped, '52 Beechcraft Bonanza
Long Beach, California
- jzanutto
a brand new Pingel should NOT leak in the off position
