Z1 fuel cock
09 Jan 2009 18:58 #257030 by jzanutto
Z1 fuel cock was created by jzanutto
has anyone used the z1 petcock adapter plates on a 650? it says the bolt holes are 44mm apart, and I measured mine and they are 44 apart, so it should work.
just want to see if anyone has used these....
1978 KZ650B 2004 BMW R1150RT
  • oldkaws4ever
  • Have no regrets...... You only live once.
09 Jan 2009 20:04 #257035 by oldkaws4ever
Replied by oldkaws4ever on topic Z1 fuel cock
Yup, i have one on my 650b1 and its a perfect fit. If ya get the petcock, you have to enlarge the petcock hole on the bottom just a bit to fit the filter.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
09 Jan 2009 22:31 #257058 by jzanutto
Replied by jzanutto on topic Z1 fuel cock
ok then thats what I'm gonna do. I bought one of those for my H2 and I like it because it has an OFF position. I hate those vacuum petcocks.
  • oldkaws4ever
10 Jan 2009 00:12 #257062 by oldkaws4ever
ya me 2, i always replace the vacume ones with the manual petcocks, mutch less hassle.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • Iron Duke
  • what are you rebelling against?
13 Jan 2009 11:27 #257668 by Iron Duke
Replied by Iron Duke on topic Z1 fuel cock
I have a 82,550 with vac petcock, is it 44mm, will the fit be same as on 650?
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
  • KOOL RYDER
  • KZ 650B2 / KZ 1000E
13 Jan 2009 12:56 #257673 by KOOL RYDER
Replied by KOOL RYDER on topic Z1 fuel cock
Hey Guys,
Can someone explain to me the difference between the vaccume and the manual petcock?
On my 650 B2 the vaccume hose connects to the carbs, I am assuming that this hose is eliminated when using the manual.
SO - do you need to block off the hole where the old vaccume tube used to go?
ThnX
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
13 Jan 2009 13:33 - 13 Jan 2009 13:42 #257680 by Patton
Replied by Patton on topic Z1 fuel cock
KOOL RYDER wrote:
Hey Guys,
ThnX
Vacuum petcock is designed to be always OFF (in either PRI or RES position) until actuated by receiving vacuum from a running engine. Eliminates need to remember physically (manually) turning it OFF when the engine is shut down. Manual petcock has three positions, which are ON, OFF and REServe.
Converting from vacuum to manual eliminates the vacuum hose, at which time the vacuum nipple at the carb should be capped off where the hose previously attached.
FYI -- manual's ON (and RES) are same through fuel flow as vacuum's PRIme.
Good Luck! :)
Last edit: 13 Jan 2009 13:42 by Patton.
13 Jan 2009 14:36 #257701 by RonKZ650
Replied by RonKZ650 on topic Z1 fuel cock
Like patton said you do block the vacuum line if replacing a vacuum petcock with a manual type. You can either remove the hose from the carbs and plug it at the carbs or simply plug the hose with a bolt or something. Conversely if you feel the need to convert a 1977 manual type petcock with a vacuum one you can simply tie the vacuum line to any of the 4 carb sync ports on the intake rubbers. The manual petcocks on the 77 and prior KZs were a piece of crap. I use the vacuum type and rarely have a problem. The diaphram is only like $10 and will fix most problems.
13 Jan 2009 15:00 #257706 by Patton
RonKZ650 wrote:
...The diaphram...will fix most problems.
Z1E lists the vacuum petcock diaphram for $12.46
and the full vacuum petcock kit for $22.49
Good Luck! :)
14 Jan 2009 06:53 #257825 by wiredgeorge
Replied by wiredgeorge on topic Z1 fuel cock
If a vacuum petcock is fitted, I would remove the carb holder with the vacuum fitting the petcock will be connected to and turn it so that the vacuum fitting is pointed upwards. They tend to collect gas when pointed down in their normal orientation and the gas can cause the petcock diaphragm to deteriorate prematurely. On the 650, I would probably use the #1 carb for vacuum as it is fairly easy to put a hose from a manometer on that vacuum fitting when synchronizing.
14 Jan 2009 16:11 #257903 by eaglecrash2
Replied by eaglecrash2 on topic Z1 fuel cock
I just installed a pingel manual shutoff on my '77 650 and even in the shutoff position there is still a puddle of fuel under the bike the next day. Still the same old problem. Maybe I should have nought the expensive model?
'77 kz650,'06 Vulcan 500ltd, '07 ducati 1098s, '03 bmw m3, '85 carrera, '71 911s, '06 s2000, '03 suburban, '76 triumph TR6
sold: '69 honda 250, yr(?) 50cc honda moped, '52 Beechcraft Bonanza
Long Beach, California
14 Jan 2009 17:31 #257918 by jzanutto
something's not right there... take off your fuel line and route it to a little can or something and just sit and watch it
a brand new Pingel should NOT leak in the off position
