- Thank you received: 1
CARB COMPATABLITY
- Z1109R Fin
Well these are 34's Not flats tho. They did come off a '82 kaw csr so i was told. Looks like only one jet inside and its a 122.5. Everything seems to be great on it. Bolted up fine, cable is good. Had to put choke on all the way just to get to start,push it in it dies. All 4 plugs are sparking bright white but if i touch the exhaust pipes only one is getting hot, other 3 are still cold even after a min or two. All 4 bowls have gas but i have to be missing something. Any suggestions???
"Looks like only one jet inside...." And you got it started:huh: Okay so you´re basicly cooling 3 cyls with fuel cause they are sucking in all the fuel they can:P Or do you mean in every carb only one jet?
Z1000R ´83...Slightly modified...
- wiredgeorge
- XTREMETOPGUN_30
- Mcdroid
- Gone Kwackers
- Thank you received: 318
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- XTREMETOPGUN_30
- XTREMETOPGUN_30
- wiredgeorge
