CARB COMPATABLITY
- XTREMETOPGUN_30
24 Sep 2008 18:02 #238522
by XTREMETOPGUN_30
CARB COMPATABLITY was created by XTREMETOPGUN_30
Hi i have a 79 kz 1000 ltd. Lookin to use a set of 34mm flatslides of a GXSR 1000 carbs. So what is anyones input? Thnks for your time.
- Z1109R Fin
- Thank you received: 1
25 Sep 2008 05:09 #238571
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic CARB COMPATABLITY
Early Gigser carbs go in pretty well. Kwak 2&3 intakes are a bit too wide for those carbs but just a little force they will fit. By 34mm flatslides you mean flatslide CV-carbs? Early Gigsers came with Mikuni TM33 mechanical flatslides which are pretty rough but I just love them. CV (vacuum operated slides) are probably much more civilized as the manual slides are more racing-touch.
- XTREMETOPGUN_30
25 Sep 2008 16:10 #238660
by XTREMETOPGUN_30
Replied by XTREMETOPGUN_30 on topic CARB COMPATABLITY
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
25 Sep 2008 16:49 - 25 Sep 2008 16:54 #238664
by Skyman
West Linn, OR
Replied by Skyman on topic CARB COMPATABLITY
Hard to tell from the photo with pods in the way, but those look like BS34 CV carbs, no?
Here's what flatslides look like:
Am I wrong?
Am I wrong?
West Linn, OR
Last edit: 25 Sep 2008 16:54 by Skyman.
- XTREMETOPGUN_30
25 Sep 2008 17:00 #238667
by XTREMETOPGUN_30
- Skyman
26 Sep 2008 11:22 #238778
by Skyman
West Linn, OR
Kind of hard to tell with such a tiny photo (could you bump up the image size any?), but they still look to me to be BS34 carbs.
These carbs came standard on later model ('81+) KZ1000s and KZ1100s. I think you should be able to get them to work on your '79, but there are some changes you will need to make.
You'll need to get larger intake manifold boots to accomodate the 34mm ports. Also, your bike's stock carbs probably used a two-cable push/pull throttle setup. The BS34s only use a single pull cable. And the cable ends for this type of carb are different than stock--so you may need to either do some resarch to find out if you can get a cable that will attatch to your throttle handle up top and this type of carb at the bottom; OR you may need to switch to a different throttle control housing up top and use a standard throttle cable from a later model year.
As for adjustments to jetting and all that, I'll defer to our resident carb guru, WiredGeorge on that one.
West Linn, OR
- kano
- Not Another Bloody Limey!
28 Sep 2008 09:05 #239045
by kano
Replied by kano on topic CARB COMPATABLITY
- Z1109R Fin
30 Sep 2008 00:27 - 30 Sep 2008 01:02 #239371
by Z1109R Fin
In Extremetopguns pic they may well be flatslide CV carbs from a GSXr.
One way to check is yo open the top cover. If the slide is roundshape then they may be BS34´s. If the slide is flat then its, well flatslide probably from a GSXr.
In following pic you´ll see TM 33 mechanical flat slides from a GSXr. CV flat slide have a round top cover (red circle in pic) where the vacuum diapfram is.
Last edit: 30 Sep 2008 01:02 by Z1109R Fin.
- PLUMMEN
- Thank you received: 104
30 Sep 2008 03:48 #239378
by PLUMMEN
Replied by PLUMMEN on topic CARB COMPATABLITY
whats been done to the motor?
- XTREMETOPGUN_30
30 Sep 2008 04:02 #239381
by XTREMETOPGUN_30
Only thing done to motor was a head job by schnitzin the spring but all stock except pods and and 4 in 1 v&h. The person i bought it from had cut the baffle may need reaplaced. If anything else was done i dont know,but likes stock all the way.Thx
- PLUMMEN
30 Sep 2008 08:30 #239428
by PLUMMEN
unless theres been some serious headwork done and a set of cams id stick with something more in the area of 28-29 carbs myself.leave the 34 flatslides for dragbikes ,ive never used the cv style carbs .i know of a really healthy 1385 streetbike here in town that runs just fine with 36 flatslides and thats a whole lot more motor.
- XTREMETOPGUN_30
01 Oct 2008 21:45 #239753
by XTREMETOPGUN_30
Well these are 34's Not flats tho. They did come off a '82 kaw csr so i was told. Looks like only one jet inside and its a 122.5. Everything seems to be great on it. Bolted up fine, cable is good. Had to put choke on all the way just to get to start,push it in it dies. All 4 plugs are sparking bright white but if i touch the exhaust pipes only one is getting hot, other 3 are still cold even after a min or two. All 4 bowls have gas but i have to be missing something. Any suggestions???
