carb help?
- kano
- Not Another Bloody Limey!
Re: carb help?
22 Feb 2007 18:02
i have a set of these.
someone did a good tutorial on syncing carbs a while ago on here.
look in the carb section for it bro.
Post edited by: kano, at: 2007/02/22 21:02
Re: carb help?
22 Feb 2007 19:12
Before commencing synch work, would suggest (1)assuring no air leaks and (2)determining which if any individual cylinder is responsible for the ultra-high idle. Synching is usually one of the last tune-up procedures after everything else (ignition, spark, timing, compression, valve lash, any necessary internal carb adjustments and cleaning, etc.) is correct.
- boomboom45
Re: carb help?
22 Feb 2007 20:03
thanks. when i get off work tomorrow, or maybe saturday, ill do a spark plug check, ill start with #3, because thats where i did the work. i dont know if i asked this, but what if i have the jet needle set at the wrong height, will that cause this problem?
Re: carb help?
22 Feb 2007 20:19
boomboom45 wrote:
Doubtful, as jet needle has negligible effect at idle speed which is based almost entirely on the pilot circuit. Jet needle becomes effective as the throttle opens.
...if i have the jet needle set at the wrong height, will that cause this problem?
- boomboom45
- boomboom45
Re: carb help?
23 Feb 2007 13:17
conventional, i think. they are the standard mikuni carbs that came on it
- boomboom45
Re: carb help?
25 Feb 2007 16:16
hey patton,
well i tried to crank it up, wouldnt stay running. im in the process of tracking a short, no power anywhere. i have gone over the carb intake boots, and checked to make sure there are no cracks, everything looks good, if i could have kept it going i could have done the spark plug check. ill try that during the week.
Re: carb help?
25 Feb 2007 21:50
boomboom45 wrote:
The leaks of most concern are in connections between carbs and engine (not in the carb intake boots between the carbs and airbox). Recall the spray test earlier mentioned (requires a running engine).
hey patton,
- boomboom45
Re: carb help?
26 Feb 2007 11:47
actually i meant the other side, where you are talking about. not sure the names of everything, the book i ordered is not here yet. i removed the airbox already.
- jeffreygp
Re: carb help?
02 Mar 2007 13:34
Hello, have you check if your slides are sticking or seated properly? Even a tiny increase in the slide opening causes the engine to race.
