carb help?
- boomboom45
carb help?
19 Feb 2007 17:05
i just cleaned out my carbs, and removed the airbox, but my idle is way to high, about 5500 rpm. the idle screw is backed all the way out, and i cant find any loose hoses, anyone have any ideas?
- pyxen
- boomboom45
- arobsum
- Kiwiz
- boomboom45
- boomboom45
Re: carb help?
20 Feb 2007 05:05
where would i look? i checked the carbs, and i didnt feel or hear anything.
- Kiwiz
Re: carb help?
20 Feb 2007 10:55
What sort of carbs are they? Convenional slide or diagphram?
Re: carb help?
20 Feb 2007 11:16
boomboom45 wrote:
With engine running, could spray propane gas, WD40, or starting fluid, around the intake manifolds. A leak will usually suck in enough spray to cause a noticable difference in rpm. This should help diagnose whether there's a leaking intake manifold (torn or cracked) or maybe just a loose or ill-fitting clamp.
Re: carb help?
20 Feb 2007 11:22
boomboom45 wrote:
Were any sync adjustments done, either on the bench or on engine while running?
- kano
- Not Another Bloody Limey!
Re: carb help?
20 Feb 2007 11:22
i would say that the clamp from cylinder rubber number 3 is stopping your butterfly s on the carb from shutting
its happened to me before.
- boomboom45
