carb help?
  • boomboom45
  • boomboom45's Avatar Topic Author
carb help?
19 Feb 2007 17:05
#113665
i just cleaned out my carbs, and removed the airbox, but my idle is way to high, about 5500 rpm. the idle screw is backed all the way out, and i cant find any loose hoses, anyone have any ideas?
  • pyxen
  • pyxen's Avatar
Re: carb help?
19 Feb 2007 17:10
#113666
is your choke set up properly?
84 KZ550-F2 LTD
93 ZR550-B4
  • boomboom45
Re: carb help?
19 Feb 2007 17:27
#113674
first thing i checked, but ill recheck it
  • arobsum
  • arobsum's Avatar
Re: carb help?
19 Feb 2007 19:23
#113717
look for a big air leak maybe?
  • Kiwiz
  • Kiwiz's Avatar
Re: carb help?
19 Feb 2007 21:20
#113767
Throttle cables snagged, out of their stops etc?
  • boomboom45
Re: carb help?
20 Feb 2007 05:04
#113792
checked that, everything is good.
  • boomboom45
Re: carb help?
20 Feb 2007 05:05
#113793
where would i look? i checked the carbs, and i didnt feel or hear anything.
  • Kiwiz
  • Kiwiz's Avatar
Re: carb help?
20 Feb 2007 10:55
#113888
What sort of carbs are they? Convenional slide or diagphram?
Re: carb help?
20 Feb 2007 11:16
#113892
With engine running, could spray propane gas, WD40, or starting fluid, around the intake manifolds. A leak will usually suck in enough spray to cause a noticable difference in rpm. This should help diagnose whether there's a leaking intake manifold (torn or cracked) or maybe just a loose or ill-fitting clamp.:)
Re: carb help?
20 Feb 2007 11:22
#113894
Were any sync adjustments done, either on the bench or on engine while running? :unsure:
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
Re: carb help?
20 Feb 2007 11:22
#113895
i would say that the clamp from cylinder rubber number 3 is stopping your butterfly s on the carb from shutting
its happened to me before.
  • boomboom45
Re: carb help?
20 Feb 2007 15:12
#113937
which clamp? do i have to tear it down?
