Z500 for racing
- Sixten
Z500 for racing
20 Oct 2020 02:18
Hi,
I´m thinking about using an early Z500 for Classic racing.
Has anone here some experience from doing that?
I think what i need to do first is fitting an oilpan from newer 550 that has outlets for oilcooler and fit oilcooler, Change to steel braided brake lines and good pads and maybe harder front springs.
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: Z500 for racing
20 Oct 2020 07:10
Welcome to the forum sixten.
Here in the states we never had a Z500. We are going to have limited experience with racing one. There are a few racers here, but we dealt with the KZ/GPz line of bikes. I did some racing on a 500, but it was a Yamaha. Not sure that's gonna be any help. I can tell you I didn't run a cooler on it, if that helps at all.
And Welcome again.
And Welcome again.
Re: Z500 for racing
20 Oct 2020 07:51
The Z500 is almost same as the 550, only with a 3mm smaller bore. Tons of guys raced those bikes so there should be lots of info available. Corey Clough is a member here with lots of experiencing racing 550's. You might want to look him up and pick his brain.
- loudhvx
Re: Z500 for racing
21 Oct 2020 14:04
Huh, multiple oil pan questions today. Here are some things to look for in 550 oil pans.
s3.amazonaws.com/gpzweb/OilPans/Kz550oilPans.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Sixten
Re: Z500 for racing
01 Mar 2021 02:18 - 01 Mar 2021 22:49
Yes it is the same bike as KZ550 I understand.
I bought a bike and fitted some old fairings, big oil cooler, 4-1 exhaust, foam air filters, steel braided lines and new pads.
I shortened the front springs and put a long spacer to compress the spring more and welded one of the holes in the “damper” to get more damping.
But the forks are still not very good
Maybe it’s possible to use forks from another bike? Preferably one with 18” wheel as 19” racing tires are limited.
It has to be parts that was available 1980 because of the regulations for classic racing in Sweden.
The only racing tires I found are Avon AM18, F2 and AM26.
Has anyone here got any experience from those?
Last edit: 01 Mar 2021 22:49 by Sixten. Reason: .
- turboguzzi
Re: Z500 for racing
14 Mar 2021 00:58
hi sexten, nice bike, good to see another racer from europe.
i raced for many years in the italian championship 500 class, but with a Honda CB500/4, never had a z500 in the class even if they were sold in italy
Later i raced also a Gpz550 but it was in a bigger class due to cc
did you put an oil cooler at the end?
can you explain what is the problem with the fork? in theory you did the right thing by shortenng the springs and adding spacers, the question is what is the spring rate AFTER the change. in any case the post 1984 gpz550A model fork is much better, maybe try to find one
- Sixten
Re: Z500 for racing
17 Mar 2021 23:21
Hi,
Did the CB500/4 race in the same class as a Z500 would?
Yes i put a big oil cooler behind the front fairing.
it was to big to sit in the original place.
I didn’t measure the spring rate after I cut it but it still feels week.
I will try it on track and add pressure to the forks until it’s stiff enough.
also the “damping” it not very good still but I bought very thick oil and will try that.
is 84 GPZ the same diameter? 36mm
- Sixten
Re: Z500 for racing
11 Jun 2021 12:44
I have now tried it on track and the forks are very bad.
Also I cant find a 19” front tyre that will survive racing in hot conditions.
So I want to swap the front forks for something bigger and with a 18” front wheel.
any advice on possible swaps?
It has to be parts available in 1980 or similar tech.
- 750 R1
Re: Z500 for racing
11 Jun 2021 18:41I have now tried it on track and the forks are very bad.
The first model Z1R Kawasaki {1978} ran an 18 inch front wheel, so did the KZ1000 police bikes from 1978 onwards, I think they were 2.15 inch wide, The Z1300 also ran an 18 inch front wheel but is disc spacing is very wide so I wouldn't use one of those...
- loudhvx
Re: Z500 for racing
11 Jun 2021 20:35 - 11 Jun 2021 20:35
The manual lists the 1984 Zx550A1 (Gpz550) as having an 18" front wheel. Most likely the 1985 Zx550A2 (Gpz550) would as well.
The forks on those models had anti-dive features, but I think Corey Clough figured out it was easier and better to just convert to stiffer springs and block off the anti-dive system for racing.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 11 Jun 2021 20:35 by loudhvx.
- doctorcat
Re: Z500 for racing
06 Jul 2021 07:24I also found out similar. I have an 83 gpz550 with the air assist. Having ridden some more modern bikes with damper rod forks properly set up (racetech cartridges) I wanted something cheaper but good.The manual lists the 1984 Zx550A1 (Gpz550) as having an 18" front wheel. Most likely the 1985 Zx550A2 (Gpz550) would as well.
I blocked off air assist by removing all the over the fork tube paraphernalia, then I threaded the air holes for a tiny flat and shallow grub screw. Then used some marine epoxy to really seal the hole shut.
Then I did YSS fork cartridges (or race tech if you have $$$ for them) and drilled out the damper rods as per the instructions and installed them.
The forks are a lot better. I set them stiffer than I should have (my bike is considerably lighter than the factory bike and I'm not as heavy as I expected myself to be by about 50 lbs now thanks to diet and some modest exercise) but they work great.
- Sixten
Re: Z500 for racing
08 Feb 2025 14:08 - 08 Feb 2025 14:38
I will continue this topic.
What started as an interest for racing has developed to an interest for classic bikes and mostly Kawasakis.
I started racing with a GSXR600 but realized modern racing is too fast for me and I didn’t like to switch between slicks/raintyres.
The 1980 500cc class in classic racing looked fun so I got the Z500. It has now developed a bit and got a new look. Inspired from an Z500 Isle of Man F2 racer in 1980.
Then I wanted a bike for the 1300cc class. Z1s was to expensive so I bought a Z650 frame and put a GPZ750 engine in it.
It worked beyond expectations and I hade a good chance in the championship but I was disqualified because the GPZ engine was too modern. Many of my competitors run bigger and even newer engines than me so I didn’t like that.
Decided to try to win the championship next season and built another 650 but with a 650 engine this time. With 810cc kit, better suspension, brakes, magnesium wheel and lots of weight saving.
Painted it like Crosbys Suzuka/Isle of Man Z1.
I know some people don’t like this as it’s not real but I think it looks fun. The front fairing is acctually from the same
mould as the original bike and the wheels are Marvic Morris replicas. Otherwise nothing the same.
This bike is fast and has won every race in its class. I ended up winning both the 1300cc and 500cc championship.
But I wanted a better 500 so I decided to build the Moriwaki Zero X1 400FX replica.
Here is the frame finished and painted. I hope to put it together before the seasons starts.
Last edit: 08 Feb 2025 14:38 by Sixten.
The following user(s) said Thank You: rstnick, Injected, Nessism, sf4t7, Rolf1976_KZ900, kimchella
