Zukiworks build's a ZRX
- zukdave
22 Feb 2017 18:17
Always wanted a rex and about a year or so ago a buddy calls said he's got a deal for me on a 99 ZRX
bad motor but with ALL the stuff to build a motor for it and a 91 ZX-11 that needed a fuel pump, a chain and fork seals
but was a nice running bike when Will started the fork seal job then stopped.
Made it to Will's about 1 0-clock and got the two bike's and a van load of parts.
Full Muzzy Ti. system for the rex.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
Re: Zukiworks build's a ZRX
22 Feb 2017 18:24
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
22 Feb 2017 18:39 - 22 Feb 2017 18:41
Fast forward I ended up with no money in this pile of parts so didn't need to sell the ZX-11 to pay for it
so I pull the ZX motor and put it in the ZRX.
With 4" over D-G chassis swing arm and the ZX rear 5.5" wheel with a 190 tire.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 22 Feb 2017 18:41 by zukdave.
22 Feb 2017 18:39zukdave wrote: Always wanted a rex and about a year or so ago a buddy calls said he's got a deal for me on a 99 ZRX
SCORE.:woohoo:
- zukdave
22 Feb 2017 19:07
Score hell at this point in the build I've made $600 bucks selling off the extra parts
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
22 Feb 2017 19:14
DOUBLE SCORE :woohoo: :woohoo:
- zukdave
24 Feb 2017 18:08 - 24 Feb 2017 19:00
Steve this bikes gonna be a handle full think about it the stock ZX motor is rated at 147 hp. stock ZRX is 106 hp. at the crank.
The full Muzzy left side exh., the ign. stuff I've got, and the 40 mm flatslides am working getting I'm thinking should
go 140's at the tire
Instead of wasting this chunk of alum. trying to fit carbs on the down draft head in the side draft frame.
I've been using some chunks of hickory to make test pieces to make the adapter's. I can cut a new one pretty
quick on the band swa drill some hole's and see how the carbs fit.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 24 Feb 2017 19:00 by zukdave.
24 Feb 2017 19:00
Gonna be a handful alright. Pics?
- bluej58
- 650mod
26 Feb 2017 08:45
I'll be keeping my eyes peeled on this one for sure. Definitely going to rip some rubber off the tail end when it's done.
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
- peter1958
26 Feb 2017 13:49
www.kzzone.com/
27 Feb 2017 09:03
can't wait to see this one come out!
