Zukiworks build's a ZRX
Re: Zukiworks build's a ZRX
14 Dec 2017 17:49
Please make sure you use acid in a well ventilated area.
Just looking out for your lungs.
Breathing is a very basic function
- zukdave
14 Dec 2017 18:40
Dave I'm thinking after spending the last 40 + years in a shop I've inhaled enough shit I'm a walking haz-mat. site.
I did do this outside by the way.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
14 Dec 2017 18:53
I've got a spare set of heel gaurds so thought I'd play with them and the drill press.
Stock.
Drilled. After this pic I added another row of holes but didn't get a pic tonight.
Stock.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
15 Dec 2017 17:41
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
15 Dec 2017 18:03
Nice work. How well does that exhaust work?
- zukdave
17 Dec 2017 16:31
Steve the pipe works great and is not to loud. I sold my buddy Dan the spare Muzzy left side pipe I had with a diff.
mid pipe and can and his ZRX is a lot louder.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
19 Dec 2017 19:38
I think I've posted about how the lower shock mounts on the swing arm are in to far and pull the
bottom of the shocks in so tonight got to looking at what I need to do to fix that.
Simple fix cut them off and make new mounts and have them welded on arm's cro-mo I don't have a Tig welder
Got to thinkin and came up with a way to use the mounts that are on it and make some adjustable mount's.
Cut a 2" thick piece off a 4x4x12 piece of alum I've got and fired up the getto mill.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- riturbo
23 Dec 2017 06:21
Nice job . Bikes coming along great
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- zukdave
23 Dec 2017 16:36riturbo wrote: Nice job . Bikes coming along great
Thanks !! Got it out for a ride the other night and pulled the wick up real hard at the top of third and into fourth
it was trying to lift the fornt tire. Top of fifth this B^%%& was rolling.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
26 Dec 2017 00:16
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
26 Dec 2017 18:14
I've had one of these Raptor two stage shift light;s I bought a few years ago and never used so think I'll finally use it and put it on this bike.
www.raptorperformance.com/collections/sh...i-shift-launch-light
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
10 Jan 2018 05:07 - 10 Jan 2018 05:09
Had this thing out last Sunday for a little ride to do some launch practice time to learn how to ride it.
Cold street so a good burn out to get some heat in the tire for the first hard launch bring the rpm's up to about 5000 rpm
slide the clutch out and pin the throttle and it's all I could do to fight the wheelie.
Second gear more wheelie's but could ride it out hit third gear it's still trying to lift the front tire and is flat hauling ass.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 10 Jan 2018 05:09 by zukdave.
