Triple tree stand
- Godfrey
Triple tree stand
08 Feb 2016 13:10
I've seen triple tree stands for sport bikes, and I'm wondering if anyone has been able to use them or something like them for older kz's?
www.amazon.com/Venom-Motorcycle-Triple-H...keywords=triple+tree
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
Re: Triple tree stand
08 Feb 2016 13:15
A small floor jack works for me and has more uses.
- JR
08 Feb 2016 14:35
My inexpensive (cheap) approach to a triple tree stand for my kz750
www.kzrider.com/forum/21-tools/595750-ra...wheel-off-the-ground
08 Feb 2016 14:39
:lol: That'll work.
09 Feb 2016 03:43
as long as there is a large enough hole in the bottom of the steering stem for the pin to slip into it will work.
- daveo
12 Feb 2016 07:33Godfrey wrote: I've seen triple tree stands for sport bikes, and I'm wondering if anyone has been able to use them or something like them for older kz's?
I've had great luck with this jig, and had the entire front-end off the bike to change the head bearings. I trust it as long as the bike's center-stand is locked, and the bike is positioned on a level and solid floor surface, and the bike isn't moved around too much while wrenching on it. Best to break-loose the nuts and bolts before jacking it, then final tighten them after the tire is back on the floor.
1982 KZ1100-A2
12 Feb 2016 08:26
Nice stand Daveo
- kzz1king
22 Apr 2016 19:33
These are all good if you have a centerstand. Any DIY ideas for those of us without?
Wayne
Wayne
Home built KZ1000 turbo setup
- GPzMOD750
22 Apr 2016 22:41kzz1king wrote: These are all good if you have a centerstand. Any DIY ideas for those of us without?
Wayne
Get a cheap paddock stand from harbor freight or cycle gear.
- DoctoRot
23 Apr 2016 02:26 - 23 Apr 2016 02:28damn your bike is clean!
I have a cheap triple stand i got on amazon and have used it on my kz650. its OK, it has a couple different pins so you can use it on a wide range of bikes.
Last edit: 23 Apr 2016 02:28 by DoctoRot.
- pete greek1
23 Apr 2016 10:31kzz1king wrote: These are all good if you have a centerstand. Any DIY ideas for those of us without?
Wayne
you can buy a rusted up center stand for cheap, & only install it when you want to raise the bike, & take it off when you're done, only two nuts & bolts, takes about 2 minutes to put on or take off
Pete
