- Thank you received: 109
stripped cam cap bolts
- mark1122
- Keep twisting it
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- roy-b-boy-b
- Thank you received: 103
Mean while i was certain the cam timing was off on the bike i bought so i have it tore down with two broken cam cap bolts. At least they are on the out side. My drill is in town so i have to make the trip for it. What size drill bit is used to drill out the bolt?
I'm hoping that work will slow down so i can work in the shop more than i have latley. This 70 hours a week is getting me down.
Roy
- wiredgeorge
- roy-b-boy-b
I am going to try and see Kon before he leaves for Greese.
I'll probably buy his A4. I really don't want to visit NYC but for Kon i will.
Kon is sending two sets of carbs a set of 28s and a set of 26s. Roy
- timebomb33
I THINK MY POWERBAND BROKE
- bountyhunter
- Thank you received: 337
I read my service bulletin direct from Kawasaki for the KZ650 and it says 8 ft/lb on camshaft cap bolts. Like I said earlier 12 is way to much and they will strip. Even 8 is pushing it.
Yep, I'll bet a lot of them get stripped because there aren't many torque wrenches with an accurate range that goes down that low. I have a 16 ft-lb (max) wrench perfect for it.
- timebomb33
- BSKZ650
- Thank you received: 14
as for lube or not, if you add lube to them the torque needs to increase to compenstae for the lube, since the spec was for dry,
anti sieze is not a good product to use on torque bolts, it can allow them to back off after time, dont know why but it does.
Studs seem like the best soultion to me, then all the "work" is being applied to the stud not the alum thread.
77 ltd1000, current rider
76 kz900, just waiting
- 78kz650b
Mine-05' Ducati S4R
Wifes- 78' KZ650B
02' Harley FXDL Custom
- shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- wiredgeorge
- 79MKII
- Love Them Kaws!
- Thank you received: 43
Either way, be careful to torque accurately when installing the cam cap bolts. I think overtorquing is the primary culprit when threads are stripped. It's very east to over-torque.
Keep us posted and good luck!
The Kaw List:
