- Thank you received: 58
stripped cam cap bolts
- APE Jay
- Banned
How about using longer studs threaded into the cam bolt holes,and drawing the cam caps down with nuts on the studs.Then removing the studs 1 at a time and installing the proper bolts,and then torque.
Then again, how about replacing all of the bolts with studs, and never have to take them out of the head again.
Jay
- arobsum
- Thank you received: 10
Jay
- larrycavan
- Visitor
I agree with Jay on the assy. lube. Steel and aluminum need a barriar between them....
- nads.com
- Thank you received: 20
Post edited by: nads.com, at: 2006/10/31 00:55
Post edited by: nads.com, at: 2006/10/31 02:08
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- nads.com
- auggiedog
One thread talked about redrilling/tapping to 7mm. Will this still leave the dowel pin/guide in good shape?
If I went the route of going to 8mm on all the holes, it seems that all of the dowel/locators would be gone. How is this done by all those drag race guys? Is the bolt enough to locate the cam cap?
While putting in studs seems like a good idea, I would think that if by chance one of the nuts worked loose, it would creat havoc on the top end, where if the bolt works loose, it can not come out due to it's length. has anyone done the stud thing?
Thanks all!
K
- ronjones
- Thank you received: 4
RonJ
- Conti
What broke :
Yeah, I know, it's written in French. Don't mind.
I drilled a small hole with a 1mm drill, PERFECTLY in the middle of the bold. If you don't drill exactly at that point, it's far more difficult to extract the broken bolt. I use a vertical driller, and I used a spirit level to be sure to drill vertically.
I used those tools:
More information about those tools
I drilled a larger hole with a small drill bit. That drill bit is not the common kind. It's made to drill a hole especially for extraction.
Then, I used the extractor. The stud came out:
The extractor is on the left, and the drill bit on the left. The drill bit costs a fortune. The full set (5 drill bits and 5 extractors) costs around USD 160. However, it's the best quality tools you can ever find.
- RonKZ650
- Thank you received: 240
- wiredgeorge
- Conti
I use mostly the SQUARE shaped extractors now. They are far harder to break than the EZ-Out shown. I am not familiar with the drill on the right. I use an automatic center punch and a cobalt drill bit.
The special drill on the right costs 4 times more than the extractor in itself. As you can see, it has a V shape. The extractor also has the same V shape. Thanks to that shape, the extractor grips in the bolt all along the drilled hole. Using a normal drill wouldn't be that efficient, since the extractor would pull the bold only on its upper part, and the extractor would probably break itself.
I often used those drills and extractors, they work as a charm.
