stripped cam cap bolts
- wiredgeorge
- RonKZ650
- Thank you received: 240
- APE Jay
- Banned
- Thank you received: 58
Jay
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- 79MKII
- Love Them Kaws!
- Thank you received: 43
The Kaw List:
- larrycavan
- Visitor
When installing cams, the factory method only promotes ripping the threads out.
Once the cams are laying in the head and properly timed, the best method is to start the cam caps that have the least amount of travel before mating with the head surface.
You want to set all 4 in place with the bolts in them, sticking down into the bolt holes so you can aline the two shoulder bosses on the cams properly.
Put a 10mm socket on the bolts and spin them down with your fingers.
The manual tells you to start #3 cap first. That particular cap is then pushing #2 intake valve open and putting severe strain on the threads.
- Duck
- e vica na i sau na ga
- OnkelB
- Thank you received: 80
Suzuki, in the GS1000 FSM, says to clamp the camsaft in place with long nosed vie grips so as not to be pulling against the valve springs.
1045 posted an excellent tip about that technique a while back, hereĀ“s a link to the thread in the archives:
kzrider.com/forum/viewthread.php?tid=24241
77 KZ 650 B1, 82 GPz 1100 B2.
- wiredgeorge
Duck - In this case, I doubt clamping the cams in place would have made a difference. On the last cap I had to fix, the cam was already solidly down as it was the on the last two bolts to be torqued and I carefully snugged the last bolt with a wrench before using the torque wrench and it just spun the thread out. There was absolutely no pressure from the cam since there were seven other bolts already torqued. This was just strange as it hasn't happened before.
Post edited by: wiredgeorge, at: 2006/10/29 18:58
- wallyworld
- wireman
- Visitor
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
