125 HP?
- Lorcan
- Speed Loony
Re: 125 HP?
01 Oct 2006 13:45
That would put the gearbox as absorbing about 8 Kilowatts, and the chain about 5kw, in which case it should be glowing red hot.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- caffcruiser
Re: 125 HP?
01 Oct 2006 14:41
Lorcan wrote:
You mean yours doesn't?
- BohicaBob
- wireman
Re: 125 HP?
01 Oct 2006 19:07
the only dyno i worry about is the seat of my pants
horsepower is just a number ,putting it to ground is whats important.if it dont hook up or you dont know how to use it all the horsepower in the world wont do you any good:evil:
- caffcruiser
Re: 125 HP?
02 Oct 2006 04:55
wireman wrote:
Horsepower isn't really anything actually besides an equation. It's an arbitrary number, made up by someone to sell stuff. It's like the term "democracy". It's not tangible, its not naturally occuring in nature, and it's a man made concept.
Torque, on the other hand, IS something pretty awesome.
Why build a motorcycle for horsepower? It's pointless. It's a small, lightweight machine. Build them for torque and they are more fun. Look at the old kawi triples! :woohoo:
PS: Like the new avatar! :laugh: They were the absolute best.
Post edited by: caffcruiser, at: 2006/10/02 07:59
the only dyno i worry about is the seat of my pantshorsepower is just a number ,putting it to ground is whats important.if it dont hook up or you dont know how to use it all the horsepower in the world wont do you any good:evil:
- steell
Re: 125 HP?
02 Oct 2006 05:13
HP = Torque x RPM / 5252
Would you be happy with 100 ft lbs of torque at 1000 rpm and 1 ft lb of torque at 5000 rpm? If so, then what you want is a diesel powered motorcycle
Torque will get you there.
HP will get you there faster.
:laugh: :laugh: :laugh:
72 H2 750 torque 7.9 kg-m at 6500 rpm
78 KZ1000 A2A torque 8.1 kg-m at 6500 rpm
76 KZ750B1 torque 6.0 kg-m at 3000 rpm
80 KZ750E1 torque 6.4 kg-m at 7500 rpm
79 KZ1300A1 torque 11.8 kg-m at 6500 rpm
83 GPz1100 torque 10.2 kg-m at 8000 rpm
I'm reasonably certain that a 83 GPz1100 would beat a 79 KZ1300 at the drag strip and in top speed, but if torque is king and nothing else matters, then obviously we should all be riding KZ1300's (or 750 twins)
I'd like to see a torque curve for all the above bikes, just to see if the 750 twin would beat all others at 3000 rpm
I can't find the torque rating for the GPz750 Turbo at the moment.
Post edited by: steell, at: 2006/10/02 08:47
- modprod
Re: 125 HP?
02 Oct 2006 05:41
steell wrote:
Yes HP tells you how much work can "potentially" be done in a given amount of time. Torque alone does not tell you that.
- wireman
Re: 125 HP?
02 Oct 2006 07:11
caffcruiser wrote:
Post edited by: wireman, at: 2006/10/02 10:16
torque?you cant handle the torque:evil:wireman wrote:the only dyno i worry about is the seat of my pantshorsepower is just a number ,putting it to ground is whats important.if it dont hook up or you dont know how to use it all the horsepower in the world wont do you any good:evil:
PS: Like the new avatar! :laugh: They were the absolute best.<br><br>Post edited by: caffcruiser, at: 2006/10/02 07:59
- wireman
Re: 125 HP?
02 Oct 2006 07:11
torque is required to make horsepower,horsepower just tends to overtake it at a certain point in rpm range.
Post edited by: wireman, at: 2006/10/02 10:14;)
Post edited by: wireman, at: 2006/10/02 10:35
- Duck
- e vica na i sau na ga
Re: 125 HP?
02 Oct 2006 07:53
torque is energy is work is force applied over a distance
power is energy/unit of time. it's the rate of doing work
horsepower
horsepower
- Lorcan
- Speed Loony
Re: 125 HP?
03 Oct 2006 12:02
BohicaBob wrote:
OK, I've read it. I can't see anything there that explains what happens to the 14HP (10 Kilowatts!) my drive chain is absorbing according to your rule of thumb though. Maybe it errr...evaporates?
Hopefully you can explain, as we are building a 1000hp bike and I don't want the chain absorbing 60hp. That's a whole engine's worth for some people! :whistle:
Checkout more info: True Horspower <br><br>Post edited by: BohicaBob, at: 2006/10/01 19:14
760cc - 8.69@162mph
- 77KZ650
Re: 125 HP?
03 Oct 2006 12:13
Lorcan wrote:
That wouldnt be that monster turbo big bore GPZ1100 you were thinking about awhile back is it? :evil: :evil: :evil:
1000:woohoo:my 650 only started out with 64:lol:Hopefully you can explain, as we are building a 1000hp bike and I don't want the chain absorbing 60hp. That's a whole engine's worth for some people! :whistle:
07 MDP Rookie of the Year
