125 HP?
- Exitpupil
125 HP?
29 Sep 2006 06:39
I got tired of my old car projects and am really enjoying working on a bike for a change. I have a couple of questions:
What modifications would I need to get around 125 crank hp from my 79 KZ1000?
What is the rule of thumb for percent hp loss to the rear wheel on a chain drive bike?
Thanks, this forum is great!
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- caffcruiser
- Exitpupil
Re: 125 HP?
29 Sep 2006 07:37
Ah-ha Caffcruiser. I've gone that route on cars before and it is fun till the bottle runs out. I know you are poking fun, but I'm looking for typical N/A "engine mods" so the power is always there. "no officer, those aren't NO2 bottles, they are aerodynamic saddle bags".
- 77KZ650
Re: 125 HP?
29 Sep 2006 07:42
have you thought about turbocharging? or just a big bore motor?(or both?:evil: :evil: )
07 MDP Rookie of the Year
- andoman
Re: 125 HP?
29 Sep 2006 07:52
Take a look at
www.oldkawman.com
. He has some interesting and (I think) accurate info on HP gains with different mods. Porting, pipes, cams, big bore, high compression pistons, etc. A KZ1000 is limited to less than 125 HP due to overheating issues on the street. Your goal is probably reachable for track use.
- Duck
- e vica na i sau na ga
Re: 125 HP?
29 Sep 2006 08:39
How far up Blue Ridge are you from GA?
125HP? My 400cc Honda four is speced as 56HP@10,750RPM. 11.5:1, 4 valves/cyl, 32mm carbs. Rev limiter at 12,500 RPM ;-) It's pretty quick for a small bike.
Biggest gain comes from getting more mix in and exhaust out and increasing the temp delta(increasing compression). Reasonable displacement increase(not beyond the point where cooling capacity is reduced) wouldn't hurt. Adding oil cooler will help with increased heat dissipation requirements. This is armchair advice as all the engine building I've done has been of the 'repair/rebuild' type. No hotrodding.
- 77KZ650
Re: 125 HP?
29 Sep 2006 08:42
hey wireman, tell the guy what you have builtB)
- Exitpupil
Re: 125 HP?
29 Sep 2006 09:34
Duck, I'm on the Blue Ridge Pky about 5 miles south of the Va border.
The 83 GPZ1100 I had once upon a time was "rated" @ 120 hp and had no heating problems. It had the power level I'm looking for.
I guess I'll just live with the mild cam upgrade, bigger carbs and pipe until it needs freshing up. Then I can go with the 1075 kit, cams, porting, etc.
Losses through the chain drive anyone?
- Lorcan
- Speed Loony
Re: 125 HP?
29 Sep 2006 11:56
A bike rated at 120hp will typically make 100hp at the wheel. That's not drivechain losses though, that's marketing
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- RomSpaceKnight
Re: 125 HP?
29 Sep 2006 13:34
I've opted to got with the 12:1 WISECO 1075 kit. Like to run on steet pump gas. Sunoco Gold but not a VP or something.
- Exitpupil
Re: 125 HP?
29 Sep 2006 14:07
Romspaceknight, how do you like the kit? How does it run? Does the head flow cause it to run out of breath on top end?
Post edited by: Exitpupil, at: 2006/09/29 22:24
- Fossil
Re: 125 HP?
29 Sep 2006 17:01
andoman wrote:
I would suggest you look elsewhere than the Old Kawman.
My GPz1100 is rated at 120hp stock, what's the difference really between it and a KZ1000 regarding overheating?
I have an 1170cc big bore kit with the compression upped to 10.25:1. No overheating issue here.
I think 125hp is easily done. Porting, carbs, exhaust...APE Jay is probably the guy to set you up.
Take a look at www.oldkawman.com . He has some interesting and (I think) accurate info on HP gains with different mods. Porting, pipes, cams, big bore, high compression pistons, etc. A KZ1000 is limited to less than 125 HP due to overheating issues on the street. Your goal is probably reachable for track use.
