125 HP?
- Exitpupil
What modifications would I need to get around 125 crank hp from my 79 KZ1000?
What is the rule of thumb for percent hp loss to the rear wheel on a chain drive bike?
Thanks, this forum is great!
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- caffcruiser
- Thank you received: 2
- Exitpupil
- 77KZ650
- Thank you received: 7
07 MDP Rookie of the Year
- andoman
- Thank you received: 1
- Duck
- e vica na i sau na ga
125HP? My 400cc Honda four is speced as 56HP@10,750RPM. 11.5:1, 4 valves/cyl, 32mm carbs. Rev limiter at 12,500 RPM ;-) It's pretty quick for a small bike.
Biggest gain comes from getting more mix in and exhaust out and increasing the temp delta(increasing compression). Reasonable displacement increase(not beyond the point where cooling capacity is reduced) wouldn't hurt. Adding oil cooler will help with increased heat dissipation requirements. This is armchair advice as all the engine building I've done has been of the 'repair/rebuild' type. No hotrodding.
- 77KZ650
- Exitpupil
The 83 GPZ1100 I had once upon a time was "rated" @ 120 hp and had no heating problems. It had the power level I'm looking for.
I guess I'll just live with the mild cam upgrade, bigger carbs and pipe until it needs freshing up. Then I can go with the 1075 kit, cams, porting, etc.
Losses through the chain drive anyone?
- Lorcan
- Speed Loony
- Thank you received: 59
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- RomSpaceKnight
- Exitpupil
Post edited by: Exitpupil, at: 2006/09/29 22:24
- Fossil
Take a look at www.oldkawman.com . He has some interesting and (I think) accurate info on HP gains with different mods. Porting, pipes, cams, big bore, high compression pistons, etc. A KZ1000 is limited to less than 125 HP due to overheating issues on the street. Your goal is probably reachable for track use.
I would suggest you look elsewhere than the Old Kawman.
My GPz1100 is rated at 120hp stock, what's the difference really between it and a KZ1000 regarding overheating?
I have an 1170cc big bore kit with the compression upped to 10.25:1. No overheating issue here.
I think 125hp is easily done. Porting, carbs, exhaust...APE Jay is probably the guy to set you up.
