Seized engine kz440
- KZfreely
Re: Seized engine kz440
19 Jun 2026 23:03There’s not much to an engine R&R. Basically unbolt or disconnect everything connected to the engine (chain, clutch cable, exhaust, carbs w/air-box), remove old engine, bolt in “new” reverse the process. With a 440’s engine size, you should be able to remove the engine relatively easily due to it’s smallish size. Only advice is to make sure it’s supported well underneath before removing the last few attachment points.
Later, Doug
I still haven't been able to locate and replacement engine for some on eBay but I'm just not sure it would be worth it. I guess my other option is to start taking the engine apart and see how bad it really is maybe it's possible I could rebuild it?
- ckahleer
21 Jun 2026 08:17
I agree. You can remove the head and cylinders without taking the engine out of the bike. Try to determan if all the damage is confined to the top end. Sourcing the parts needed for repair may be easier, cheaper,and safer, than getting a complete engine.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- bound
- If you ain't HURTIN' you ain't LEARNIN'!!
22 Jun 2026 18:16
I'd say tearing that baby apart is a great idea! There ain't much better ways to learn
You dont have much to lose by taking it apart at this stage. The only thing you lose is space in your garage and some bolts... If you need any help with anything we are always here to help.
If all is lost, I am always surprised by the amount of 440s resting under tarps collecting dust. There may be a decent chance of finding a cheap parts bike in your local area on marketplace.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
- KZfreely
10 Oct 2026 14:06Thanks for the vote of confidence! I have it torn down to the cam. Unsure how to proceed as i cant get engine to TDC as it is seized. I've tried everything i can think of and have now stripped the crank bolt by timing advance. I have also put it in gear and tried rocking it with no luck. can i just put witness marks (marking paint or awl marks) by timing advance and on cam sprocket to keep things alligned? thanksI'd say tearing that baby apart is a great idea! There ain't much better ways to learn You dont have much to lose by taking it apart at this stage. The only thing you lose is space in your garage and some bolts... If you need any help with anything we are always here to help.
The following user(s) said Thank You: bound
10 Oct 2026 16:14
You don’t need to worry about timing it for disassembly, the process for setting it up on reassembly is in the manual - if it is repairable make sure you set the crank damper correctly when putting the bottom end together
- bound
10 Oct 2026 19:45
Glad to hear that you got the motivation to dig at it! As wookie said dont worry about having the motor at tdc until at reassembly. Just follow the service manual and be ready for when you have to remove the cylinder and somehow break the pistons out of there. If you have any questions please ask. The worst thing to happen is be unsure about some thing and ending up with something broken. I am guilty of this...
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
- KZfreely
14 Oct 2026 20:14So i got it taken down to the pistons and the connecting rod for left piston is completely free from the crankshaft. it looks like one of the bolts is sheared off. There is also a sizable piece of the steel sleeve in jug that is broken off and most likely inside lower crankcase. I still am going to open up case but probably engine is fubar.I'd say tearing that baby apart is a great idea! There ain't much better ways to learn You dont have much to lose by taking it apart at this stage. The only thing you lose is space in your garage and some bolts... If you need any help with anything we are always here to help.
14 Oct 2026 20:58
Ouch.
- bound
14 Oct 2026 20:59
Yeah it would probably be easier and cheaper to get a new engine but its awesome that you took it apart! Most people would freak out at the idea of doing that... a similar situation happened to another forum member on here called Stereordinary.
www.kzrider.com/forum/2-engine/622426-wh...-the-problem?start=0
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
- KZfreely
Yesterday 21:26I found a seemingly good replacement engine on ebay. It arrives in a few days. I'm keeping original engine and may attempt to rebuild if its worth it.Yeah it would probably be easier and cheaper to get a new engine but its awesome that you took it apart! Most people would freak out at the idea of doing that... a similar situation happened to another forum member on here called Stereordinary. www.kzrider.com/forum/2-engine/622426-wh...-the-problem?start=0
- bound
Yesterday 10:40
If you haven't checked yet, the 440s were pretty abundant and not very valuable so you wouldnt be hard-pressed to find a parts bike for a couple hundred bucks in your area. Shipping on engines is pretty expensive so it could almost be cheaper to buy a parts bike instead of the engine. In my area I found 3 for sale for $150-$300.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
- KZfreely
Yesterday 11:57I checked around Craigslist and marketplace since around April. The closest parts bike I found was half a state away. I definitely over paid when you consider shipping costs, but I love this bike and every other aspect of it is almost pristine. Labor of love I guess lolIf you haven't checked yet, the 440s were pretty abundant and not very valuable so you wouldnt be hard-pressed to find a parts bike for a couple hundred bucks in your area. Shipping on engines is pretty expensive so it could almost be cheaper to buy a parts bike instead of the engine. In my area I found 3 for sale for $150-$300.
