Seized engine kz440
  • KZfreely
  • KZfreely's Avatar Topic Author
Seized engine kz440
25 Apr 2026 12:30
#923322
What can idiot I let my bike run on oil and seized up while riding I don't know how bad the damage is I can get it to rotate with a wrench on the crankshaft bulb but no luck getting it started with the starter any advice?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Seized engine kz440
25 Apr 2026 12:36
#923323
Bottom line is you need to strip the motor and inspect, likely crank bearings scrap, cam bearings scrap, piston skirts may have picked up in the bores and damaged the pistons, cam lobes possibly damaged. Every bearing in the motor will of overheated !!!
  • KZfreely
25 Apr 2026 13:25
#923325
That's kinda what I figured. Would it be easier/cheaper to just replace engine? Thanks for reply man
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
25 Apr 2026 16:05
#923330
Probably
  • Nerdy
  • Nerdy's Avatar
26 Apr 2026 10:26
#923365
Probably
If by "probably" you mean "1000%", then yes :-D
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • Michi
  • Michi's Avatar
26 Apr 2026 10:37
#923366
The replacement engine might also be bad - you just don't know.
KZ440A LTD (1980)
  • Nerdy
  • Nerdy's Avatar
26 Apr 2026 10:45
#923368
Of course - that's the same risk as with with any used bike.
A rebuilt engine is no guarantee of quality, either, as it could have been done poorly.
All we can do is get as much info as possible prior to purchase :)
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
  • Michi
  • Michi's Avatar
26 Apr 2026 11:25
#923372
A few years ago a guy in England was selling an old KZ440 engine on Ebay. Clearly had been left outside - no idea what was wrong with it. He was selling it as an ornament/conversation piece! His advert even suggested turning it into an outdoor table or leaving it in the garden as a sort of gnome. Those were the days when record shops, hairdressers, burger shops and cafes used to decorate their interiors with random automotive artefacts. Maybe OP could yet find some use for that engine.
KZ440A LTD (1980)
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
26 Apr 2026 11:29
#923373
Personally I would strip it before parting with any money - there is always a slim chance that it’s not terminal (cam bearing nipped up etc)
The following user(s) said Thank You: hardrockminer, KZfreely
  • KZfreely
14 May 2026 21:01
#923938
I have located a replacement engine on eBay. Is swapping out the 440 engines fairly straightforward? I have limited mechanical experience but am determined to not let this bike die. Thanks all
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
14 May 2026 23:26
#923940
Just take your time and follow the manual
  • H1Vindicator
  • H1Vindicator's Avatar
15 May 2026 09:00
#923956
Do you mean it ran low on oil? did the oil light come on while you were riding? in case it needs to be said: check the oil level at the oil gauge sight glass before every ride. and check it whenever making a pitstop. bike level on center stand. no start: is the battery good and fully charged? do a load test.
