Whelp! I found the problem.
  • Nerdy
  • Nerdy's Avatar
Re: Whelp! I found the problem.
05 Jan 2026 13:48
#920348
That's about 128 thousandths, or just a very tiny bit over 1/8" - seems about right, given the pics.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: Stereordinary
  • Daftrusty
  • Daftrusty's Avatar
05 Jan 2026 14:07 - 05 Jan 2026 14:11
#920349
 Perfect time to consider the zx600 engine swap…………
Last edit: 05 Jan 2026 14:11 by Daftrusty.
  • Nessism
  • Nessism's Avatar
05 Jan 2026 15:11
#920351
A new/used crank is a high likelihood.  Rods don't just come loose without thrashing the crank.  You'll know soon enough, though...
The following user(s) said Thank You: SWest, Stereordinary
  • Stereordinary
  • Stereordinary's Avatar Topic Author
05 Jan 2026 16:18 - 05 Jan 2026 16:18
#920354
A typical stock Kawi air cooled liner is about 3.25mm thick.
I measured it just now and it’s a bit under that, at 2.9mm. But I happen to have another “barrel/jug/block” on hand here, and it measures 2.85mm. I suppose it’s possible that it was bored just a bit at some point. But I think it’s more likely that it’s stock, and my measuring accuracy is not perfect.
Definitely something I’m thinking about. Before I knew it was possible (which was just very recently), I had purchased a Wiseco big bore kit for it (probably over a year ago). I’d been waiting to find a set of ZX550A cams to swap in when doing the kit, and also having a second bike to ride while this one was in my shop. But now with this happening, I’m playing it by ear. It’s not necessarily easy to just find and buy a good ZX600 engine, but I am looking.
A breeze from the west.
Last edit: 05 Jan 2026 16:18 by Stereordinary.
  • Daftrusty
05 Jan 2026 17:52 - 05 Jan 2026 17:59
#920358
I hear that!
I am also finding it impossible to find a donor zx600 for the motor and accessories.
But the instant I do, I’m putting my spare zr550 engine up for sale.
You could always look for a zx550 motor and use an offset sprocket. It has higher compression, better cams, everything from the zr motor bolts right up (exhaust, carbs, ignition, oil cooler…etc) and has the correct clutch cable mount. All that and bolts right in to the Zephyr frame. It will still need all the same preventative maintenance as any other spare motor.  But it’s honestly getting hard to find a gpz/zx550 motor that isn’t already clapped out.  I bought a eBay zx550 motor that showed a video of it running and everything. It arrived on the pallet with #3 rod welded to the crank. But their ad “technically” did not say that it was a running motor. They refused any wrong doing and I had no recourse but yo eat it.
I at least got my 1980’s Moriwaki ignition cover from it.
Lots of options to weigh.
Last edit: 05 Jan 2026 17:59 by Daftrusty.
  • Injected
  • Injected's Avatar
05 Jan 2026 19:11
#920359
According to the 650/750 FSM those nuts do not get any Loctite. I guess Kawaski thought they did not need thread locking, maybe because of the super fine thread? Or maybe the fact that there is tension from the clamping action??
I have a spare set of rod bolts so I do know they are a fine thread, but not a lock nut. I replaced the bolts/nuts on my 650 drag bike with M8 and pretty sure those are a mechanical type lock nut.
1978 KZ650B2 modified project
  • Stereordinary
05 Jan 2026 19:48
#920361
You could always look for a zx550 motor...
I get what you're saying. But since I already have the big bore kit, I'm leaning towards fixing this engine, though maybe using parts from other 550 variant engines.
...those nuts do not get any Loctite. I guess Kawaski thought they did not need thread locking...
According to a knowledgable friend of mine, they make the underside of the flange on the nut ever so slightly concave, so that when they are tightened the flange flattens out and puts a lot of pressure on the bolt. And the bolt is meant to stretch as well, making it even tighter.
This same friend also said that he puts red thread locker on them when doing his drag race car engine assemblies anyway. He said that "while red thread locker is supposed to be permanent, I don't care, anything with threads can be taken apart."
  • Injected
  • Injected's Avatar
08 Jan 2026 08:18
#920429
I double checked those nuts and they do have about a 5 degree negative angle on the bottom, smooth with no serrations. Loctite could not hurt for the extra piece of mind but you would have to back off on the torque setting by about 10% if I remember correctly.
Nuts held with red Loctite will come off easily with some heat from a propane torch.
  • Stereordinary
10 Jan 2026 10:48 - 10 Jan 2026 10:48
#920484
As luck would have it, I may have found a donor bike for this local to me. Question about it though, I understand that it’s the ZX600 A/B/C motor that is a direct fit, and I can see that those motors look different from later model engines. Most notably the cam chain is in the middle of the motor rather than off to the right hand side. But it looks like the “D” model engine is somewhere in between the earlier and later designs. So will a D engine also fit, or only the A/B/C motors?
Last edit: 10 Jan 2026 10:48 by Stereordinary.
  • Daftrusty
10 Jan 2026 15:49 - 10 Jan 2026 18:38
#920498
I have found numerous zx600D bikes near me for parts, but unfortunately the D bikes have a totally different motor. Different architecture, with forward-tilted cylinder and head, cam chain is on the side, different ignition system and carb and exhaust spacing is no longer sharable with zephyr/kz/gpz/ zx……
Only zx600a/b/c bikes will work. The B model is the Ninja 600rx that had an all-one-piece aluminum frame unlike the steel modular frame regular Ninjas had. Those bikes are very rare, so I wouldn’t expect you to come across one.
Last edit: 10 Jan 2026 18:38 by Daftrusty. Reason: Grammatical errors
  • Stereordinary
20 Mar 2026 20:09
#922429
Now I’m starting to wonder why it’s so hard to find ZX600 A, B, and C engines when anything that’s a D engine or other is plentiful. I’m having the same problem as you described, Daftrusty. I really don’t want to go the eBay engine route. Too many things to go wrong. But it’s like the early ZX6’s (or GPZ600, or ZZR600, or whatever) have all fallen off the face of the planet.
I’m not finding any suitable ZR550 engines either, for that matter.
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
22 Mar 2026 09:32
#922464
Don't forget that the Ninja 600 bikes were super popular with young new riders and most of them got worn out or totaled and scrapped. Same thing with the Honda 700/750 Interceptors and Suzuki GSXR's. And then there's all the bikes used up by racers.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
