z750L: Repair starter clutch
Re: z750L: Repair starter clutch
25 Jun 2025 06:12
There is a tutorial on using screws to reattach the basket together. I'll look for it for you, but it's linked on the 750 turbo site. Personally, I'd rather have it TIG'ed. Anyone that half way knows what they are doing can do the welding for you. My guy used low temp silicon bronze rod.
The following user(s) said Thank You: gordone, Wookie58
- riturbo
25 Jun 2025 06:28 - 25 Jun 2025 06:33
Here you go found it . Ive done it both ways welding and bolts . Both works . I think welding is much easier as driving those old rivets out isn't easy
Clutch Damper Change (1).pdf
Edit Couldnt get it on here for some reason . Its on this page scroll down a bit
clutch repair - urgent warning - Page 20 - 750turbo.com
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Last edit: 25 Jun 2025 06:33 by riturbo.
- gordone
25 Jun 2025 06:38
Project:
Project:
25 Jun 2025 06:44 - 25 Jun 2025 06:47
The rollers can get caught in those grooves. At minimum, I'd polish out any edges.
Clutch damper change article attached below. Please let me know if it didn't attach correctly.
Last edit: 25 Jun 2025 06:47 by Nessism.
The following user(s) said Thank You: riturbo
25 Jun 2025 06:49
The following user(s) said Thank You: kimchella
- gordone
26 Jun 2025 06:18The rollers can get caught in those grooves. At minimum, I'd polish out any edges.
I’ve decided to order a new "CLUTCH-ASSY-ONEWAY" (13193-1062) as well. From what I understand, this means the starter clutch will now be completely new, correct?Based on the pictures and what we've seen so far, what do you think the issue was with the starter — considering that we haven’t found any obvious or complete damage?Could it simply be wear and tear on the springs, pistons, and the CLUTCH-ASSY-ONEWAY?
Project:
Project:
26 Jun 2025 06:53
I believe it was simply a "wear" issue - given that it works as intended with the plugs removed it appears that it couldn't generate enough "friction" when under load
26 Jun 2025 06:59
My guess is that the cause is an accumulation of wear on all the various parts. And of course, that 810cc piston kit of yours puts even more load on the starter clutch.
Member Daftrusty installed a sprag type starter clutch from a later model 750 into his engine. That would be the ultimate fix (I think). I'm pretty sure the new parts you are purchasing should solve the problem, though.
- gordone
27 Jun 2025 03:36 - 27 Jun 2025 03:37
Should I replace the rubber damers in sec. Shaft?
see video for rotation slack.
see video below:
drive.google.com/file/d/1h-Uy79Ku2PSjs85...Al/view?usp=drivesdk
see video below:
Project:
Project:
Last edit: 27 Jun 2025 03:37 by gordone.
27 Jun 2025 03:56
Makes sense while you are in there, you can then forget about it for many years to come
- gordone
27 Jun 2025 04:28 - 27 Jun 2025 04:31
Will order, guess it will reduce wear due to less vibration between shafts also?
looking forward to see if I can feel and hear difference with new rubber in starter hub and clutch hub… the free rotation in clutch was quite a lot…
Project:
Project:
Last edit: 27 Jun 2025 04:31 by gordone.
27 Jun 2025 07:21I can't view the video. Are you talking about the dampers in the primary drive chain cush hub? If so, those were shrunk on my bike, so I replaced them.Should I replace the rubber damers in sec. Shaft?
see video below:
