Help with First Restart After Carb Rebuild
Re: Help with First Restart After Carb Rebuild
17 Apr 2025 16:30Get what you are saying and it seems logical, I only suggested a basic spark check given that #2 & #3 dropped which are on the same coil - however if the posted readings are correct this has thrown up a couple of issues, the coils should be between 2 & 3 ohms on the primary side but have measured as 5 ohms which will give a weak spark and also there appears to be a significant volt drop in the coil feed which will also weaken the spark further. This could be carb related but could also be the result of disturbing wiring when re-fitting the airbox ??Coil resistance spec is something like 2.2 ohms.
Let's reset here. First start had the engine reving out to a high rpm, right? That can't happen if the plugs are not firing. Boots replaced, airbox installed, then problems start. Sounds like something carb related, not spark.
Do the choke flaps move smoothly with the lever? They often bind up, and hang open, thus choke doesn't work, which causes hard starting. Some starter fluid, carefully used, will test that possibility.
- SnyperX
17 Apr 2025 18:08 - 17 Apr 2025 20:23Get what you are saying and it seems logical, I only suggested a basic spark check given that #2 & #3 dropped which are on the same coil - however if the posted readings are correct this has thrown up a couple of issues, the coils should be between 2 & 3 ohms on the primary side but have measured as 5 ohms which will give a weak spark and also there appears to be a significant volt drop in the coil feed which will also weaken the spark further. This could be carb related but could also be the result of disturbing wiring when re-fitting the airbox ??Coil resistance spec is something like 2.2 ohms.
I tried a different multimeter. When I used my second meter and took the resistance readings again on the primaries I got EXACTLY 2.4 ohms on each coil.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
Last edit: 17 Apr 2025 20:23 by SnyperX.
17 Apr 2025 20:13Your coils are likely good.Get what you are saying and it seems logical, I only suggested a basic spark check given that #2 & #3 dropped which are on the same coil - however if the posted readings are correct this has thrown up a couple of issues, the coils should be between 2 & 3 ohms on the primary side but have measured as 5 ohms which will give a weak spark and also there appears to be a significant volt drop in the coil feed which will also weaken the spark further. This could be carb related but could also be the result of disturbing wiring when re-fitting the airbox ??Coil resistance spec is something like 2.2 ohms.
I tried a different multimeter. When I sued my second meter and took the resistance readings again on the primaries I got EXACTLY 2.4 ohms on each coil.
- KzEnormous
17 Apr 2025 23:20
I'm not the sharpest knife in the drawer, so I try not to over think a situation. Instead I revert to the basics and go over my work again.
1980 Kz 1000 Ltd -
Currently in resurrection
1980 Kz 440 Ltd -
Waiting for attention, possible sale or part out.
1982 Kz 1000 -
Part donater, sale or scrap metal
1980 Kz 440 Ltd -
1982 Kz 1000 -
- SnyperX
18 Apr 2025 07:41So I attempted to start it again yesterday afternoon. I did get it running and idling at around 1k rpm, but it seemed to bog down at times when giving it throttle. Most of the time however it revved strong up to like 4k rpm. Now, after it had been running and I killed the engine I tried to start it again. This second attempt it didn't want to start and when it did it was missing a couple cylinders again. I had a high power shop fan blowing on the engine to keep temps decent as well. So I am wondering if my coils might have an issue once they has heat soaked from the engine?Your coils are likely good.Get what you are saying and it seems logical, I only suggested a basic spark check given that #2 & #3 dropped which are on the same coil - however if the posted readings are correct this has thrown up a couple of issues, the coils should be between 2 & 3 ohms on the primary side but have measured as 5 ohms which will give a weak spark and also there appears to be a significant volt drop in the coil feed which will also weaken the spark further. This could be carb related but could also be the result of disturbing wiring when re-fitting the airbox ??Coil resistance spec is something like 2.2 ohms.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
18 Apr 2025 07:45
That is easy enough to check. Warm the engine up a gain, shut it off and immediately check the coil resistance. If you have a heat gun, you may be able to warm the coils up enough that way.
- SnyperX
18 Apr 2025 10:34
Made a video of how it will bog down after idling well for awhile.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
18 Apr 2025 11:02
When checking your coil resistance also check between the primary circuit and the mounting lug incase the coil is going to ground when hot (insulation breaking down)
The following user(s) said Thank You: SnyperX
18 Apr 2025 12:08
That could also be a clogged fuel tank vent. If the vent is clogged, a vacuum will form in the tank, preventing the flow of gasoline to the carbs.
To test this theory, run the engine with the fuel tank cap open and see if it bogs down. Please save your cigar for later to avoid a major redecoration job.
- SnyperX
18 Apr 2025 12:10So the petcock on my KZ750 has two connection. The fuel line and a vacuum line, does that make a difference for the test you mention?That could also be a clogged fuel tank vent. If the vent is clogged, a vacuum will form in the tank, preventing the flow of gasoline to the carbs.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
18 Apr 2025 12:14leave it connected, it is not affected by the test. Also, if it is disconnected, the bike will be running on three cylinders until the fuel bowls run dry, then it will die.So the petcock on my KZ750 has two connection. The fuel line and a vacuum line, does that make a difference for the test you mention?That could also be a clogged fuel tank vent. If the vent is clogged, a vacuum will form in the tank, preventing the flow of gasoline to the carbs.
18 Apr 2025 13:12 - 18 Apr 2025 13:13PS: forgot to mention (if you didn't already know) when measuring resistance disconnect the wires from the component being measured (otherwise you will get a false reading through the circuit) and you need to test "hot" when the fault is presentWhen checking your coil resistance also check between the primary circuit and the mounting lug in case the coil is going to ground when hot (insulation breaking down)
Last edit: 18 Apr 2025 13:13 by Wookie58.
The following user(s) said Thank You: MFP-Joe, Gdizard, SnyperX
