Help with First Restart After Carb Rebuild
- SnyperX
Re: Help with First Restart After Carb Rebuild
17 Apr 2025 07:47I did not crank the engine. I had the key in the 'On' position only when testing volts.When you say "switched the key to start" do you mean "turned the ignition" on or "cranked the motor" - if cranking the motor the battery voltage will drop to around 10V then bounce back when you stop cranking (this is due to the heavy load drawn by the stater)
Yup, that's exactly what i did. Used the ground terminal on the battery as well. I would also note that the voltage of the battery also dropped when I switched the key to start. With the key off the battery returned back to its nominal voltage.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
17 Apr 2025 07:51
What did the voltage drop to when you switched on the ignition and what position was the kill switch in ? I wouldn't expect a significant drop under these conditions unless the battery was weak (although it appears to retain enough energy to operate the starter !)
- SnyperX
17 Apr 2025 07:53The kill switch was in the "Run' position. Voltage drop was maybe a volt from the battery to the coils. From like 12.2v to 11.2v.What did the voltage drop to when you switched on the ignition and what position was the kill switch in ? I wouldn't expect a significant drop under these conditions unless the battery was weak (although it appears to retain enough energy to operate the starter !)
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
17 Apr 2025 08:07Did you take a reading across the battery when you turned the ignition on ?The kill switch was in the "Run' position. Voltage drop was maybe a volt from the battery to the coils. From like 12.2v to 11.2v.What did the voltage drop to when you switched on the ignition and what position was the kill switch in ? I wouldn't expect a significant drop under these conditions unless the battery was weak (although it appears to retain enough energy to operate the starter !)
Try connecting your voltmeter red lead to battery positive and black lead to coil supply then turn on ignition with kill switch in the run position (this will measure the difference between the battery and the coil feed) any more than 0.5v indicated an issue that will increase the longer the circuit is active - if your reading is more than 0.5v and everything else works ok I would suggest you fit a "by-pass" relay ref the link I posted (this is much easier and quicker than working back through multiple connections to check volt drops etc)
The following user(s) said Thank You: SnyperX
- SnyperX
17 Apr 2025 08:47Thanks Wook!! I was already considering the by-pass after the previous posts. I also measured the ohms. The Primary reading is about 5 ohm on each coil and the secondary is about 11k - 12k ohms per coil. I am wondering with the 5 ohm readings on the primaries that I might in fact have a coil issue as well.Did you take a reading across the battery when you turned the ignition on ?The kill switch was in the "Run' position. Voltage drop was maybe a volt from the battery to the coils. From like 12.2v to 11.2v.What did the voltage drop to when you switched on the ignition and what position was the kill switch in ? I wouldn't expect a significant drop under these conditions unless the battery was weak (although it appears to retain enough energy to operate the starter !)
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
17 Apr 2025 08:52
It is a little high (I believe the spec for your bike is 3-4ohms) the higher resistance will give a weaker spark (especially when coupled with a "volt drop")
- SnyperX
17 Apr 2025 08:58I am looking at new coils from Z1 and then doing the by-pass. I don't have an age on the coils so they could be fairly new or 40 years old.It is a little high (I believe the spec for your bike is 3-4ohms) the higher resistance will give a weaker spark (especially when coupled with a "volt drop")
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
17 Apr 2025 09:28
Coil resistance spec is something like 2.2 ohms.
Let's reset here. First start had the engine reving out to a high rpm, right? That can't happen if the plugs are not firing. Boots replaced, airbox installed, then problems start. Sounds like something carb related, not spark.
Do the choke flaps move smoothly with the lever? They often bind up, and hang open, thus choke doesn't work, which causes hard starting. Some starter fluid, carefully used, will test that possibility.
- SnyperX
17 Apr 2025 10:21 - 17 Apr 2025 14:03Ness, yes choke flaps move smooth. I also lubed the choke shaft. In addition I made sure the spring was tensioned enough to make sure the flaps would open fully when disengaged.Coil resistance spec is something like 2.2 ohms.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
Last edit: 17 Apr 2025 14:03 by SnyperX.
- KzEnormous
17 Apr 2025 14:02I agree with Nessism.Let's reset here. First start had the engine reving out to a high rpm, right? That can't happen if the plugs are not firing. Boots replaced, airbox installed, then problems start. Sounds like something carb related, not spark.
1980 Kz 1000 Ltd -
Currently in resurrection
1980 Kz 440 Ltd -
Waiting for attention, possible sale or part out.
1982 Kz 1000 -
Part donater, sale or scrap metal
1980 Kz 440 Ltd -
1982 Kz 1000 -
17 Apr 2025 14:42Take this for what it's worth, but I've found that lubing the shaft increases drag, and cause the flaps to hang up. Hopefully, your set is different, though.Ness, yes choke flaps move smooth. I also lubed the choke shaft. In addition I made sure the spring was tensioned enough to make sure the flaps would open fully when disengaged.Coil resistance spec is something like 2.2 ohms.
- SnyperX
17 Apr 2025 14:56Take this for what it's worth, but I've found that lubing the shaft increases drag, and cause the flaps to hang up. Hopefully, your set is different, though.Ness, yes choke flaps move smooth. I also lubed the choke shaft. In addition I made sure the spring was tensioned enough to make sure the flaps would open fully when disengaged.Coil resistance spec is something like 2.2 ohms.
Hmm. Interesting. I used a really light oil and it was only s couple drops where the shaft passes through each carburetor. I guess I don't understand the engineering of the carbs enough to understand how the oil might cause binding.
Regards,
SnyperX
1981 KZ750H2 LTD
SnyperX
1981 KZ750H2 LTD
