Piston Hole Kz1000LTD 1982
- cartal
Re: Piston Hole Kz1000LTD 1982
17 Nov 2024 10:42
Available at Cmsnl for 184 euros + shipping. It’s a lot of money! But then again, I see no other way to
move forward. My previous experience
with used pulse generators is that will be almost in the same condition, and I will be wasting time and money.
I do have, lying around in a box, a Dyna ignition I bought for the kz900 some 20 years ago,
but never got to install.
would that work?
would that work?
- cartal
17 Nov 2024 10:51
I’m just letting my mind wander; but if this problem
comes from the pulse generators, that would make the bike go on two cylinders…. Could have this been the cause for the cylinder hole that started this thread and this bike restoration?
perhaps the guy got the symptoms, and ignored them, leading to the catastrophic result
but i digress… I think I just need to get these new pulse generators
17 Nov 2024 11:30 - 17 Nov 2024 11:33
This would be my choice (it does actually list this as for the early and late KZ so what you have for the 900 may be ok) miss-firing could potentially have caused the issue !! Lot's of guys on here using these
Last edit: 17 Nov 2024 11:33 by Wookie58.
The following user(s) said Thank You: cartal
- cartal
17 Nov 2024 11:46
As I understand it "yes" and you can pick up the connections at the plug for the original igniter. Perhaps one of the guys who are using this system can speak up ?
17 Nov 2024 11:56
- cartal
17 Nov 2024 12:47 - 17 Nov 2024 12:50[
attachment=173817]IMG_4541.jpeg[/attachment]
Took Me a while to find the right box, but here’s what I’ve found.
i have a complete brand new in the box dyna 3 system, and additionally I also have an extra pulse “board” that probably came from ebay too.
if I am reading your picture right, I could use the current coil setup if I was to use the dyna. Right?
Last edit: 17 Nov 2024 12:50 by cartal. Reason: Add pics
- cartal
17 Nov 2024 14:14
Actually, as I already have the kawa igniter. I could just use the extra “board” I have and simply connect it to the existing cables.
would that work?
would that work?
17 Nov 2024 15:16
I don't know if the dyna pick-ups are compatible with the factory igniter, you could check the system you have is compatible (contact dyna) with your bike and fit the complete dyna system you already have
- cartal
18 Nov 2024 09:15
Got a reply from Dynatek. As follows:
Decision now is to go factory or dynatek.
my concern on going stock, is that perhaps the igniter will fail soon or is failing already, and spending cash on the factory part will be wasted.
what do you guys think?
18 Nov 2024 09:23
Personally I would go with the DS2-1 (either genuine or the copy I posted) I don't know about yours but the wires on my original igniter have hardened and the insulation cracks every time you flex the cables
- cartal
18 Nov 2024 09:45I´m definitely inclined to go the copy way, as the cost is a fraction of the original (DS2-1).Personally I would go with the DS2-1 (either genuine or the copy I posted) I don't know about yours but the wires on my original igniter have hardened and the insulation cracks every time you flex the cables
Do you have the feeling a copy will be up to the test?
