Piston Hole Kz1000LTD 1982
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Piston Hole Kz1000LTD 1982
03 Nov 2024 06:54
#905730
Like it Clay - always more than "one way to skin a cat" :)
  • cartal
  • cartal's Avatar Topic Author
03 Nov 2024 06:56
#905731
Carbs installed again. All vacuum ports blocked. Started well with just some choke.
Runs ok, and keeps good idle, but:
1.- when you rev it up it stays there for a while, then slowly comes back to idle (always read this is due to an intake leak, but sprayed with carb cleaner and saw no changes
2.- Right hand exhaust smokes quite a bit. Smells rich, not oil related. In the same exhaust there is a distinct misfire around 3-4000 rpm
The rest looks good. All 4 cylinders are firing, there’s no fuel leaks anywhere.
I guess I need to work on my “richness” part. I understand pilot screws are the ones to adjust here.
Some videos for reference
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
03 Nov 2024 07:36
#905732
You could try disconnecting the throttle cable and rev it manually (this will determine if the "hanging revs are carb or cable related)
Smoke on a fresh built motor is normal (assembly oil needs to burn off which could take 100mls or so) if it's fuel smoke it would normally be black
  • asphalt900
  • asphalt900's Avatar
03 Nov 2024 07:37
#905733
Just more crap. Yamaha XS1100 also used the 34's. Same as Suzuki 3-bypass holes. But Cartel or anybody else curious, note the initial bench syncing by using the First Intake side bypass hole as a gauge. Set, same #3 initially then follow thru with the remainders. Won't get a screaming high idle and purposeful for drawing in petrol where it's initially needed, enrichment system. Same premise works for any Butterfly carb. Wookie is that like Lynard Skynyrd or just skynarding a Cat, rock and roll cat?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
03 Nov 2024 07:42
#905734
Clay It's an old English phrase when there is more than one way to achieve the same objective "there is more than one way to skin a cat"
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
03 Nov 2024 07:55
#905735
kzrider.com/forum/attachment/100509
KZ1000K2 LTD 1982 USA CANADA
1982 KZ1100-A2/1170 sleeper 😀
  • cartal
03 Nov 2024 10:11
#905737
Well… as our friend Winston said, “this is not the end, it’s not even the beginning of the end, but it’s the end of the beginning”.
It’s been a long time, and after so much time and effort, I just felt I needed to get all the shiny bits on the bike.
I know carbs are not yet ok, and I know there will still be a lot of fine tuning to be done, but I had to indulge myself.
Gentlemen, please take a look…
Thank you. I would have definitely never arrived here without your help.
Regards,
Carlos
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
03 Nov 2024 10:32
#905738
Looks great Carlos, well done to you sir. She has recovered from her abusive previous owner.
Is that a Jaguar XJS in the background (you sir are a glutton for punishment :))
The following user(s) said Thank You: cartal
  • cartal
03 Nov 2024 11:04
#905740
That´s a really keen eye, my friend. It is indeed, a V12 XJS. Actually, 2 of them. A UK one I owned back when I lived in London, which is very rusty, and of course RHD, and a Spanish "rolling chassis". Next project will be to change everything from one to the other. That is going to be a really long project!
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
03 Nov 2024 11:38
#905742
Apparently the 5 speed manual from the 3.8 is a relatively easy conversion and makes the V12 a totally different animal :)
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
03 Nov 2024 14:16 - 03 Nov 2024 14:20
#905748
My methode to sync the carbs :
Sync carbs #4 to #3 = ( master pair #1)
Sync carbs #1 and #2 = ( slave pair #2) independent of cabs #3 and 4 (master pair #1)
Sync pair #1 (carbs #1 and 2) and pair #2 (carbs #3 and 4)
Repeat the procedere if needed for a fine adjustment.
Last edit: 03 Nov 2024 14:20 by Scirocco.
  • sf4t7
  • sf4t7's Avatar
03 Nov 2024 20:23
#905754
Carlos - bike looks great
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
