79 KZ1000 head removal
  • 750 R1
  • 750 R1's Avatar
Re: 79 KZ1000 head removal
25 Apr 2022 18:43
#866162
1:1 acetone to atf
Try and use mineral oil ATF, the synthetic stuff like to separate from the acetone. I've been using the ATF acetone mix for 30 years or more...
  • Deuce
  • Deuce's Avatar Topic Author
26 Apr 2022 06:16
#866173
Again, you don't know how much I appreciate your guidance and input.  I've been on sites that will start treating you like an idiot if they think your question is beneath them.
What's the ratio of trans fluid to acetone, or just dump some of each in?  Luckily, I have both here at my house.
50/50    If you can get them to move then add more wood blocks until you can pull the barrels free. Don't pound on it if the crank is at bottom dead center. Hopefully water didn't get past the rings. Did you measure the holes? Looks like big bore pistons to me. If so used barrels and pistons would work or stock barrels bored to 1045/75 could make a good runner if the crank isn't shot.
Haven't measured yet. It was raining last night and unfortunately, the bike has to sit outside.  I may not get a chance to go out and work on it till this weekend.
On a side note, I did see where the shims sit on top of the buckets.
www.flickr.com/gp/162005819@N03/J055kUZ1a8
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • Deuce
26 Apr 2022 06:18
#866174
1:1 acetone to atf
I'll have to stop and get the mineral oil ATF.  All I have on hand is the Type F.
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
26 Apr 2022 06:55 - 26 Apr 2022 06:57
#866176
Hi Duece, something else you could look at ref Steve's comments about the bore size. While your "rusty hole is soaking"   If you take a wire brush and some emery paper and carefully clean the crowns of the pistons that are at TDC, if it has been bored previously you may be able to see the markings on the crown that show by how much (see below). As I understand it +1mm (2nd oversize) is the max for regular oversized pistons, after that it would be a liner or performance pistons (Wiseco, Wossner etc) which are 2 to 3 times the price of regular pistons.
Just out of interest, is the motor in your parts bike (the one with the banana frame that only turns left !) in any better shape than this one
Last edit: 26 Apr 2022 06:57 by Wookie58.
  • Deuce
27 Apr 2022 06:02
#866215
I don't think it's been bored out.  I came up with a 68 mm bore with my cheapo caliper.  I see factory is 70 mm.  I didn't get a chance to do much more than put the "mix" in the bad cylinder before it started raining.  I didn't tear into the other motor as it appeared (on the surface anyway) to have been sitting outside longer.  Right now, it's tucked safely away in my garage.
I'll have to wait and see what the machine shop says regarding the block.  This is a far cry from what I was hoping to buy regarding a KZ1000.  I was wanting to buy one that I maybe had to throw some spark plugs in and clean the tank and that would be that.    I certainly don't mind doing all this (my wallet may differ) since I will be retiring soon and I could use the extra skill set.
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
27 Apr 2022 06:30
#866217
You will get a huge sense of satisfaction when it fires for the first time
  • Deuce
30 Apr 2022 11:58
#866424
I believe so, too.
I dropped the head off and I was supposed to get the carbs, but they weren't quite ready.  Managed to wiggle the block up about 5/8ths inches on the bad side.  The good side moves freely.  Tapped on the piston using a wooden stick.  Still looks pretty stuck.  I cleaned it out and poured in some more of the concoction. I figure I'll have to let it sit a little to absorb in.  After about 5 minutes, I noticed a bubble pop up on one side, and then the other.  That's a good sign.  I told the guy that's working on the other stuff I'd have that ready for him on Monday, so I hope it cooperates.
For my other bikes, eBay was my go-to place for parts, but something's happened to them in the past year or so.  I couldn't find the gaskets I need.  Where do you guys recommend I look?
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • hardrockminer
  • hardrockminer's Avatar
30 Apr 2022 12:10
#866425
The critical gasket is the two piece head gasket.  I only use OEM, purchased from Partzilla.  I normally use OEM base gaskets but will use Vesrah if OEM isn't available.
  • Deuce
01 May 2022 05:41
#866459
Thank you!  I'm assuming the Partzilla gasket will be both pieces?  Otherwise, it's over 200 dollars.  In your opinion, what issues crop up using a cheaper one?
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • Rick H.
  • Rick H.'s Avatar
01 May 2022 08:37
#866464
Deuce:  There are some differences of opinions on which style of head gasket to use.  Some like and stay with OEM type and others like a one piece arrangement.  I opted for a one piece head gasket when I rebuilt the top end on my KZ-1000.  I can't recall what exactly drove me to that decision as I tried to stay with OEM parts as much as possible.  Guess the one piece just sounded like a better option at the time which is about 2 years ago now.  At this point I don't recall who made the gasket, but I bought it from Redline (?) in Illinois and he swore by them at the time.  Knock on wood, I haven't had any problems with leaks which is fine with me.  Install for me had a bit of a learning curve as I had never installed a one piece before, but I assume I did it correctly.  If you do some research on this forum you will no doubt run across several discussions about this subject.  If I were to go with a 2 piece gasket I would try to stay with OEM regardless of the cost.  My idea of a good time is NOT having to take something apart to re-fix it.  Whichever way you go just use a really good torque wrench and remember to re-torque after the initial startup.  I went with minimum torque values on mine to avoid stripping anything out.  Ended up one and done.  Good luck.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
The following user(s) said Thank You: Street Fighter LTD, Deuce, Wookie58
  • Deuce
01 May 2022 08:53
#866467
Rick H.
Great info.  Thanks!  In my mind, I would think the one piece would be easier to install, but then again, most of my repair experience is with vintage automotive.
A little more tapping on that stuck piston and the block lifted off pretty effortlessly.  The rings on that one piston stayed compressed.
Should I re-ring just the one, or all of them?  Once I get the block to my guy, I guess that will tell me if it's going to have to be bored sleeved, or just honed.
Now, on to other parts I should get.  Regarding the cam chain, is it best practice to replace it and guides as well?  I was looking at this one pictured, and it felt too hard and has the chain indentations on it.
1982 GS1100G
1997 Yamaha Vmax
1979 Kawasaki 1000
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
01 May 2022 10:14
#866471
Glad to see you have the cylinder off
My 2 cents is  pull the motor and split the cases. You need to inspect and clean properly the  crank and trans for wear and  water damage
Replace the camchain at this point  and any worn cam chain, guides and  rollers and gears that show wear.
Dont make a piston decision until the cylinder can be checked for size, wear and pitting
Pulling the motor is easy  Especially with the top end off already and a minimal amount of extra gaskets will be needed
