Cylinder head
- zoomzoompop
Cylinder head
08 Aug 2020 18:56
I have a 81 kz650 csr h1. So I over tightened a bolt. Snap! Fucked up the hole when i drilled it out. Might be able to make it work cause its not so bad. Wondering if 80 kz650 ltd cylinder head will work if bought?
- gd4now
- Denco where did you go?
Re: Cylinder head
09 Aug 2020 14:02
Not sure. Some of the 80 models use the hyvo cam chain and some did not. But all of the 81 models did make use of the hyvo cam chain. Offl the top of my head I do not remember if the LTD used this type of cam chain or not. That is the thing I would suggest you look into.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- q-base
Re: Cylinder head
10 Aug 2020 09:26
It most likely will. When you have an existing head with everything your options are good. You can just bolt you cams and running gear from your old head into the new - if it runs a different chain type. Then main thing to consider is whether your head has the four holes threaded for the sprocket between the cams - if so - you need to find one that has this as well.
1977 kz750
Instagram: @jmreiche
- zoomzoompop
Re: Cylinder head
10 Aug 2020 14:43
What am i missing here guys? I am pretty sure its a carb issue. I have pods with 15 slow jet and 110 main. Think maybe its too big main?
Re: Cylinder head
10 Aug 2020 15:05zoomzoompop wrote: What am i missing here guys? I am pretty sure its a carb issue. I have pods with 15 slow jet and 110 main. Think maybe its too big main?
WHAT? Read your own post please.
- zoomzoompop
Re: Cylinder head
10 Aug 2020 15:19
There was spose to be a video.
Must not have uploaded.
And yes it was off topic so i get it was a little confusing.
Re: Cylinder head
10 Aug 2020 15:39
So is your post about head interchangeability or a carb issue. Might be better to open another post
- zoomzoompop
Re: Cylinder head
10 Aug 2020 16:15
Whatever you're smoke'n I want some!
The following user(s) said Thank You: Mikaw, gordone, ghostdive
- zoomzoompop
Re: Cylinder head
10 Aug 2020 16:51
Lets clear this up.
The post is about head interchangeability, but while i had others responding about that i thought maybe i could ask about the carb issue i was having because the few post i got about the heads answered that question.
Sorry it was confusing and i tried to upload a video of the the bike running to give you all a better understanding of what im seeing
Sorry about the confusion
- VTEC
Re: Cylinder head
10 Aug 2020 17:00 - 10 Aug 2020 17:03
If the hole you messed up is now too big for a helicoil. You might get away with a time-sert. Important thing when installing a time-sert is using a guide for drilling and tapping to keep it perpendicular to the surface. Some of the kits don't come with the guide. Why? I have no idea.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
Last edit: 10 Aug 2020 17:03 by VTEC.
- zoomzoompop
Re: Cylinder head
10 Aug 2020 17:10
I was able to use a helicoil. But i didnt keep the hole totally perpendicular. I found if i use a slightly shorter bolt im able to tighten up. So im good in the regard.
Thanks
Thanks
