Clarification On A Couple Of Issues
- old_kaw
Re: Clarification On A Couple Of Issues
20 Nov 2019 07:40
It looks to me that Joe at Pit Stop performance puts the base gasket on dry, yet literally glues the top end together. It also looked to me when I was trying to scrape that cylinder base gasket from hell off of my J motor that it was glued on at the factory. There are still tiny, thin pieces stuck to my engine block. I assembled it with the base gasket dry, and have seen no evidence of any leakage from the base gasket. The overpriced oval o-rings is a different story. :S
Joe's top end assembly procedure:
www.pitstopperformance.com/top-end-assembly/
Attachment not found
1981 Kawasaki Kz1000K1
The following user(s) said Thank You: Rick H.
- old_kaw
20 Nov 2019 07:43 - 20 Nov 2019 07:58zed1015 wrote: In 40 years of building these engines I have never used any sealer around those studs and have never had an issue with oil leaks or weepage of any kind.
This is on both road and race engines.
I think they mean as a thread sealer on the stud threads where they thread into the case, since the studs are exposed in the cooling fin area or the threads are open to engine oil internally.
Last edit: 20 Nov 2019 07:58 by old_kaw. Reason: hmmmmm
- zed1015
20 Nov 2019 08:22old_kaw wrote:zed1015 wrote: In 40 years of building these engines I have never used any sealer around those studs and have never had an issue with oil leaks or weepage of any kind.
I do use a spot of thread lock on the main studs but that's it.
No sealer and all those studs on the 900/1000's are in dry blind holes.
- daveo
20 Nov 2019 08:23 - 20 Nov 2019 08:25old_kaw wrote: ...have seen no evidence of any leakage from the base gasket. The overpriced oval o-rings is a different story. :S
After dealing with that issue twice, APE HD cylinder studs and nuts (40ft.lbs torque) eradicated the problem. IMO the old original cyl. studs lose strength and resistance to stretch over time and repeated use.
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 20 Nov 2019 08:25 by daveo.
The following user(s) said Thank You: old_kaw, Rick H.
20 Nov 2019 13:27 - 20 Nov 2019 14:24daveo wrote:old_kaw wrote: ...have seen no evidence of any leakage from the base gasket. The overpriced oval o-rings is a different story. :S
40 ft lbs sounds kind of high. Unless I'm missing something (a real possibility) the Kawasaki Service Manual gives a lower figure. Ed
Attachment 00003a.JPG not found
Attachment 00003b.JPG not found
Last edit: 20 Nov 2019 14:24 by 650ed.
20 Nov 2019 15:07
40 PSI is the spec for the APE studs. That's what I have now. With the stock studs I'd cringe each time I'd torque them down even at the factory settings. The last thing I wanted was to torque one down and hear the dreaded SNAP. :pinch: This time around I'll use thread locker on them.
20 Nov 2019 16:00
I've snapped a crank bolt and a couple of case bolts but never a stud. The spec for Z1 is 25 ft lbs. It was increased to 29 ft lbs for KZ 1000 but I think the studs are the same.
- daveo
20 Nov 2019 23:17650ed wrote:daveo wrote:
After dealing with that issue twice, APE HD cylinder studs and nuts (40ft.lbs torque) eradicated the problem. IMO the old original cyl. studs lose strength and resistance to stretch over time and repeated use[/i].
To look at stock and APE cyl. studs set next to one another, it might be assumed that 40ft. lbs. would be the minimum torque they could handle. :whistle:
Never measured shaft diameters when comparing them, but it is obvious to the eye that APE studs have significantly more girth. With that in-mind and without a second thought, I bored the tapers out of the oil passage holes in my last two cyl. blocks unscientifically to compensate for the additional space the APE's take up in there.
- old_kaw
21 Nov 2019 00:45zed1015 wrote: I think they mean as a thread sealer on the stud threads where they thread into the case, since the studs are exposed in the cooling fin area or the threads are open to engine oil internally.
No sealer and all those studs on the 900/1000's are in dry blind holes.[/quote]
There is nothing wrong with using loctite. If there is no chance of leakage, there is no need to seal them. I am assuming the reason KHI would specify sealing the studs, if there were a chance of leakage.
As previously stated, everyone has their own procedures. We used to coat SBC intake and exhaust gaskets with grease at a shop I worked at. The boss specified it, and threw a fit if you didn't do it right. :woohoo: Much easier to deal with if the need to go back in arises.
- old_kaw
21 Nov 2019 00:51 - 21 Nov 2019 00:51daveo wrote: After dealing with that issue twice, APE HD cylinder studs and nuts (40ft.lbs torque) eradicated the problem. IMO the old original cyl. studs lose strength and resistance to stretch over time and repeated use.
I totally agree. After 4o + years of rebuilds and re-torquing, those studs have got to be stretched beyond any maximum value. At almost $160 for the sets of APE studs and nuts, it is a moderately substantial investment.
Last edit: 21 Nov 2019 00:51 by old_kaw.
- zed1015
21 Nov 2019 01:17
You are safe to go to 32lbs on the stock studs and 42lbs on the HD ones..
Kawa increased the factory torque early on from 25lb to 29lb because of gasket leakage.
Anyone with an old manual should ignore the 25lb figure and use 29lb .
- DoctoRot
21 Nov 2019 10:35
APE specifically states to use 42ftlbs with their heavy duty studs. They are super strong, the fail-point then becomes the threads in the crankcases.
