Decked head
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Decked head
06 Nov 2019 06:24 - 06 Nov 2019 14:24
#813624
How much material can be removed from the surface of a KZ 1000 head and how can I tell if it's too much? The head is flat all along the surface area.
.002 moves freely
.003 is too tight
Last edit: 06 Nov 2019 14:24 by SWest. Reason: add pics
  • DoctoRot
  • DoctoRot's Avatar
Re: Decked head
06 Nov 2019 12:14
#813637
Whats your goal by decking the head? If you just need a fresh surface they will remove a few thousandths and it wont really effect things. If you are trying to raise compression you need to measure the combustion chambers before decking, then you can then roughly calculate how much to remove based on the compression increase you would like.
The following user(s) said Thank You: Scirocco
  • Dr. Gamma
  • Dr. Gamma's Avatar
Re: Decked head
06 Nov 2019 12:51
#813638
I believe the shop manual wants you to check diagonally across cylinder head to check for warpage
1986 RG500G 2 stroke terror.
  • SWest
  • 10 22 2014
Re: Decked head
06 Nov 2019 14:15
#813642
I suspect the head I'm working on has been decked. Maybe too much. That's why I ask.
  • DoctoRot
  • DoctoRot's Avatar
Re: Decked head
06 Nov 2019 14:20 - 06 Nov 2019 14:21
#813644
you can measure the combustion chamber volume and compare it against stock. this is how its done>
Last edit: 06 Nov 2019 14:21 by DoctoRot.
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Decked head
06 Nov 2019 14:47
#813648
I have seen them decked clear down to edge of valve W/O issues. in fact I do the drag bikes to get the quench down.
1984 750 Turbo
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Decked head
07 Nov 2019 04:11
#813664
I saw a pic of a 900 head on this site where they just about cut into the fins.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • SWest
  • 10 22 2014
Re: Decked head
07 Nov 2019 11:24
#813680
This is what I'm working with.
  • DoctoRot
  • DoctoRot's Avatar
Re: Decked head
07 Nov 2019 15:42 - 07 Nov 2019 15:46
#813691
A KZ1000 head that has been decked 1mm will only have about a 3.8CC difference from stock, you need a piece of plexiglass held on with grease and a graduated cylinder to measure accurately. The surface tension of the fluid will make it impossible to check correctly without it
this is what i use
www.amazon.com/EISCO-Acrylic-Stopcock-Ca...id=1573170359&sr=1-3
Last edit: 07 Nov 2019 15:46 by DoctoRot.
  • SWest
  • 10 22 2014
Re: Decked head
07 Nov 2019 16:15
#813692
That's OK. I found out what I needed to know. I'm going to modify the chambers like I was talking about. I'm more concerned about the voids filling with carbon then glowing causing detonation. If I lose a little compression so be it. Who knows, the engine may breath better. :whistle:
  • SWest
  • 10 22 2014
Re: Decked head
08 Nov 2019 08:30
#813712
I took a snippet out of the video I did when I installed the APE head studs. It shows the pistons below the deck almost 2mm. I don't think I'll have any problems there.
  • zed1015
  • zed1015's Avatar
Re: Decked head
08 Nov 2019 09:38
#813713
SWest wrote: I took a snippet out of the video I did when I installed the APE head studs. It shows the pistons below the deck almost 2mm. I don't think I'll have any problems there.
If correct that is quite a lot .
Each 1mm of bore equates to around 4cc and an approximate compression loss of 2 points so you will be down substantially over stock depending on the pistons used.
