KZ1000 cam tower caps
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: KZ1000 cam tower caps
22 Dec 2019 09:53
#815749
hardrockminer wrote: Do you know how the damage occurred to the combustion chamber? Was the head ported at all?
Must have been water in the cylinder. The ports hadn't been touched until I did them.
  • hardrockminer
  • hardrockminer's Avatar
22 Dec 2019 13:07
#815758
I've included a couple of close up photos of #2 combustion chamber and valves. Difficult to provide any measurements as there is nothing easy to measure from.
There is no radius on the intake or exhaust....pretty much straight into the chamber. When you mentioned it I thought well maybe....maybe someone ported the intake and exhaust on that head.
You can see the different cuts on the valve seat, (in my photo) as well as the lap for the valve. Those are all original..I have not yet re-lapped the valves.
On the valves you can see the different angles as well as the final lapped portion from when the head was new. Valves still need some more cleaning.
FYI - The early Z1 head had synchro ports located on the head for about the first 2,500 bikes. At that point they switched to the synchro ports on the intake boots. They also started Z2 production around the same time. Heads and all internals were the same for Z1 and Z2.
  • SWest
  • 10 22 2014
22 Dec 2019 13:13 - 22 Dec 2019 13:14
#815759
I thought so. Wonder if it was a later model thing? Seems flow would be improved.
Last edit: 22 Dec 2019 13:14 by SWest. Reason: sp
  • SWest
  • 10 22 2014
23 Dec 2019 07:02
#815772
This must be a virgin head. No evidence of the seats being changed.
  • SWest
  • 10 22 2014
07 Jan 2020 17:43
#816667
A little more to do.
  • SWest
  • 10 22 2014
08 Jan 2020 07:05 - 08 Jan 2020 07:07
#816689
Time to dive in. B)
The work will be in my Bossie the Kaw thread. :whistle:
Last edit: 08 Jan 2020 07:07 by SWest. Reason: Add text
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
08 Jan 2020 13:35 - 08 Jan 2020 13:35
#816717
Considering the oil burning, what are your plans with regard to the cylinders and piston rings?
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 08 Jan 2020 13:35 by daveo.
  • SWest
  • 10 22 2014
08 Jan 2020 15:04
#816728
New rings and a hone.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
08 Jan 2020 18:22 - 08 Jan 2020 18:26
#816739
Probably would have done that too, if the cylinder I had was usable.
Had to find another anyhow, since the nice one I sent Joe Hooper arrived damaged with fins broken and a couple sleeves knocked loose.
I boxed the cylinder with lots of padding, but it wasn't fastened to a board the way Joe does it. Oh well.
Can't wait to start fresh in the Spring with the top-end work all over and done, and the replaced starter clutch too.
Hoping to just get on and ride without a care in the world, especially about oil for a change. Yeah!
Last edit: 08 Jan 2020 18:26 by daveo.
The following user(s) said Thank You: Street Fighter LTD, SWest
  • SWest
  • 10 22 2014
08 Jan 2020 21:03 - 08 Jan 2020 22:12
#816747
I reused the rings when I tipped my valves. This time new rings, valves and Viton valve seals. I have my choice of sleeves to use just in case so hopefully they'll seat and no more oil burning. Won't know for sure until I open it up. :unsure:
Last edit: 08 Jan 2020 22:12 by SWest. Reason: Add clip
The following user(s) said Thank You: daveo, perrykz1000
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
09 Jan 2020 09:42
#816769
Good luck with your project. Please share the experience with us as you progress through it.
  • perrykz1000
  • perrykz1000's Avatar
  • Have a safe day !!
09 Jan 2020 12:17
#816773
Thanks Steve. I know you will keep us updated !!B)
The following user(s) said Thank You: daveo, SWest
