Oil sight glass
  • Ojisan rider
  • Ojisan rider's Avatar Topic Author
Oil sight glass
11 Jun 2018 03:26
#784914
Aloha guys.
Just as the title reads, anyone changed the sight glass for the oil/clutch cover?
Reason why I'm asking is that I recently did glass beading/blasting on my KZ parts and yeah, clutch cover been blasted as well. Now, the glass doesn't look too good and I want to replace it. I just want to make sure it's a simple remove/replace job.
If you have any advice, I'd appreciated. And if you need to see the result of glass beading, hit me. I do have some pictures of it. If you're rebuilding anything, I'm a firm believer of glass beading now. It does not remove enough materials from aluminum. Which means you need some time and patient.
BTW, don't ask me about my 7 project. I need to find me a new paint guy........................
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
  • zed1015
  • zed1015's Avatar
Re: Oil sight glass
11 Jun 2018 03:42 - 11 Jun 2018 03:43
#784915
Depending on the clutch cover type the window assembly simply presses in and out like an oil seal.
On some covers it has to come out from the front but others it will press out either way.
Last edit: 11 Jun 2018 03:43 by zed1015.
  • davido
  • davido's Avatar
Re: Oil sight glass
11 Jun 2018 08:41
#784924
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • TexasKZ
  • TexasKZ's Avatar
Re: Oil sight glass
11 Jun 2018 13:22
#784941
And best of all, the part seems to be available.....
www.partzilla.com/product/kawasaki/52005...368cec1ae9a49b5426aa
  • VTEC
  • VTEC's Avatar
Re: Oil sight glass
11 Jun 2018 16:21 - 11 Jun 2018 16:22
#784952
Carefull. Pit Stop Performance put mine in backwards and you couldn't read the level. Had to replace and install correctly. Pushes in and out easily like a seal. Lube with oil first.
KZ1000-K2
ZRX1100
XR400R
Last edit: 11 Jun 2018 16:22 by VTEC.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Oil sight glass
11 Jun 2018 16:49
#784958
This is a curious statement as I have to use a socket of the appropriate size as a driver. The back of the oil sight glass is a metal mesh type affair so not sure how Pit Stop Performance could put one in backwards. I often take a dremel with a cut off wheel and remove the mesh stuff in back as I see no purpose. It is easier to clean the glass and see the oil with that mesh gone.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Oil sight glass
11 Jun 2018 16:56
#784959
I carefully used my thumbs and pushed mine out and in my new ribbed cover years ago. I bent the mesh slightly so I can clean the glass with a Q tip and carb spray. I was going to buy a new one from Z1E until I saw the cost. Some day. :whistle:
  • VTEC
  • VTEC's Avatar
Re: Oil sight glass
11 Jun 2018 18:45 - 11 Jun 2018 18:46
#784976
The J engine clutch cover has a backing to the glass with a slot in it. The glass can go in either way, but it's off-set, so when in backwards it's up tight against the slotted backing which screws the reading. I replaced it, but after removal I could have just turned it around and put it back in. No damage.
KZ1000-K2
ZRX1100
XR400R
Last edit: 11 Jun 2018 18:46 by VTEC.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Oil sight glass
11 Jun 2018 19:33
#784983
I like the Cinema Scope Wide Screen Style.
Looks like a washing machine :laugh: :laugh: :laugh:
  • Ojisan rider
Re: Oil sight glass
12 Jun 2018 01:37
#784996
Thanks guys.
never thought to do a search as clutch cover window. Guess when you do the search, you have to use your imagination to full.
Anyway, yes. I'm ordering one soon.
  • menace
  • menace's Avatar
Re: Oil sight glass
14 Jun 2018 08:11
#785150
i used one from a zrx and it works great. i used a socket to push it in and out.
