- Thank you received: 6
Engine bog has me boggled
- Ronnie_D
- 1978 KZ1000 A2
I need a little help with this one. I have a 1978 KZ1000 A2. All stock. When I drive normal it runs fine. When I roll the throttle on from 3000 rpm it starts to accelerate but then bogs down terrible. Its like it is not getting fuel. I am not sure what is causing this
Here is what I have done so far.
cleaned and checked petcock, new gas.
thoroughly cleaned and set the floats on the carbs.
set ignition timing and checked advance, Dyna pickups and coil system.
new NGK spark plugs.
new plug wires and caps.
carb to intake connectors look good.
new combo rectifier / regulator, works fine.
I haven't checked the valve clearances but they sound good.
I do not have the airbox connected, but that shouldn't cause this issue.
It was running rich and stumbling/backfiring on acceleration before I started to tune it to a leaner setting. Now it is leaner, no backfire, but bogs down.
any thoughts on this one?
thanks,
Ron.
- Warren3200gt
- Thank you received: 715
- Ronnie_D
- 1978 KZ1000 A2
Warren3200gt wrote: 3k rpm is about where main jet becomes active. Did you clean the jets and passages when setting the floats?
I took out the jet sand their tubes, I will have a look at the passageway a bit better.
thanks,
Ron.
- Thank you received: 2234
- Thank you received: 2749
- Ronnie_D
- 1978 KZ1000 A2
I am checking the valve clearances
thanks, guys,
- Ronnie_D
- 1978 KZ1000 A2
The book says between 0.05 and 0.10 mm, is this for intake and exhaust?
thanks,
Ron.
- Thank you received: 2063
- Ronnie_D
- 1978 KZ1000 A2
The carbs are as near perfect as can be.
The valve clearance is within spec from .07 to .08, good to go.
My friend Rolf and I were working through the issue and think it is the Dyna pickups. Its seems like an ignition problem. There is nothing left.
Coils tested good.
We did a rudamentary test on the Dyna but I can't find any "how to" documents on it.
Does anyone know how to test the Dyna pickups?
I don't know the model number of the Dyna pickups. Can anyone identify it?
here's a couple of pictures...
thank you for all your help. It is appreciated.
Ron.
- slmjim+Z1BEBE
- Thank you received: 732
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
- Ronnie_D
- 1978 KZ1000 A2
slmjim+Z1BEBE wrote: What is voltage at the coil primaries vs. battery voltage? Voltage drop across the ignition switch can be significant.
Good Ridin'
slmjim & Z1BEBE
the voltage was 11.6v at the coils and 12.8 at the battery.
- Ronnie_D
- 1978 KZ1000 A2
bizzare.
any thoughts?
cheers,
Ron
