- Thank you received: 2749
KZ900 Top Idler Wear Help
01 Jul 2017 20:44 #765873
by SWest
Replied by SWest on topic KZ900 Top Idler Wear Help
The center roller is at the base gasket. Depending on what the adjuster roller looks like will tell you the condition of the center roller. They all should be changed at the same time. Also the valve guide seals. The barrels have to come off. How many miles on the bike?
The following user(s) said Thank You: coyoteduster4406
- KZB2 650
- Thank you received: 265
02 Jul 2017 07:37 #765888
by KZB2 650
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Replied by KZB2 650 on topic KZ900 Top Idler Wear Help
Take my advice with a grain of salt as most on here know 10 times more than I ever will but at 30,000 miles my stuff on my 650 was still in really good shape. I do ride 95% in cooler weather and change the oil too often so I'm sure that helped too. I just replaced the large rubber roller and got the Liska for the tensioner. Didn't want to split the case to replace the chain so I left it too. Just seems like a lot of work and cash ......now you will need all new gaskets, a valve job rings and a hone or more etc etc.......
I only ride a thousand to 1,200 miles a year too and I'll be lucky if I can swing my leg over it in another 5-6 years so that was a factor too ..... if I planned on putting 5 or more thousand miles on a year for the next ten plus well who knows what I would a done.
1978 KZ650 b-2
The following user(s) said Thank You: GPz550D1, coyoteduster4406
- coyoteduster4406
- Thank you received: 1
02 Jul 2017 08:00 #765893
by coyoteduster4406
Replied by coyoteduster4406 on topic KZ900 Top Idler Wear Help
I appreciate the input. I will likely be replacing all tensioner pieces that have any rubber/plastic as they are all the same age and condition. But i definitely won't be tearing it down to replace the chain because I don't have the money for valve seals, rings etc right now. The bike was not a smoking hulk of scrap when it was running, just severely out of tune carbs and stupid electrical issues. Doesn't mean I can't do it later
02 Jul 2017 08:06 #765896
by SWest
I gathered the parts little by little until I had all I needed. If the adjuster still works you still have time. Maybe get the idler first and the blocks that come for it. Not everyone has the $$ to do it all at once. Why did you pull the cams to adjust the valves?
- coyoteduster4406
02 Jul 2017 08:11 #765898
by coyoteduster4406
With the valve cover off i noticed the intake cam was off by one pin. Not sure if it had already been like that or if i had done it myself turning the engine backwards to test the starter clutch (i was having issues with the starter that turned out to be the starter itself). I was also checking the shim sizes and didn't have the tool to pull them without cam removal. I had no idea what a pain in the ass it is to reinstall the cams at proper timing.
- coyoteduster4406
02 Jul 2017 10:10 #765904
by coyoteduster4406
Any recommendations for head/base gaskets? Will I need to replace studs and bolts?
02 Jul 2017 11:30 #765908
by SWest
If it skipped a tooth backing it up, you may be ready to replace all the rollers.
kzrider.com/forum/13-bike-related/599607...od-guys?limitstart=0
kzrider.com/forum/2-engine/605981-valve-...kz-1000?limitstart=0
- coyoteduster4406
08 Aug 2017 08:50 #768572
by coyoteduster4406
Hey, just wanted to thank SWest and everyone else for their help and advice. Tore the engine down to the base gasket and replaced all parts of the idler system, Liska all around. Engine is back together and good, now having tuning troubles. I opened another thread if anyone wants to chime in with advice, here's the link:
kzrider.com/forum/3-carburetor/606677-kz900b-tuning-help
