Valve adjustment Z1/KZ 1000
16 May 2017 20:50
Started a unofficial thread on the subject. Enjoy.
The following user(s) said Thank You: bl_francis, Ronnie_D
Re: Valve adjustment Z1/KZ 1000
16 May 2017 21:40
17 May 2017 05:25
19 May 2017 20:51
Dialing it in.
24 May 2017 07:08
It's getting hot. Summer's here.
24 May 2017 13:09
Now that the valves are adjusted, a carb sync is next after this.
24 May 2017 21:20
Just more questions.
- Conspiracy
25 May 2017 15:44
Thanks for posting. I'll be watching.
Novice rider
1976 KZ900
1976 KZ900
The following user(s) said Thank You: GPz550D1, SWest
29 May 2017 14:59 - 29 May 2017 15:00
Looking for the chattering noise. Used my mallet against the cam to record where the noises come from. Cam chain is a little noisy too. I'll adjust it this evening when it gets cooler. 105 today.
Last edit: 29 May 2017 15:00 by SWest. Reason: sp
29 May 2017 21:12
Sounds better.
31 May 2017 17:46
I think I've narrowed it down to cam bearings. Have some on the way.
01 Jun 2017 07:35
I'll have to edit the clips and repost it on youtube. Meanwhile here's what I got.
