Pistons
  • Fox
  • Fox's Avatar Topic Author
Pistons
06 May 2017 22:49 - 06 May 2017 22:51
#761356
Hello,
Do you know what is the piston in a kz1000 ltd 78 b2?
Seems to have a lot of pistons ... www.partzilla.com/parts/search/Kawasaki/...%2778+B1-/parts.html
Piston 0.040 - 0.020 - std ... what that mean ?
Regards
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
Last edit: 06 May 2017 22:51 by Fox.
  • bountyhunter
  • bountyhunter's Avatar
Re: Pistons
07 May 2017 00:29
#761357
Fox wrote: Hello,
Regards
std is stock diameter. +0.020" and +.040" are overbore sizes.
The following user(s) said Thank You: Fox
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Fox
Re: Pistons
07 May 2017 07:20
#761372
Hello,
I gona replace the piston rings.
So std will fit ?
Regards
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Pistons
07 May 2017 07:50
#761374
You need to measure the bores. pics?
  • Fox
Re: Pistons
07 May 2017 10:01
#761408
With vernier caliper i can read bores at 69.9mm
So std i suppose?
Why is existing stock diameter.and overbore sizes ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Fox
Re: Pistons
07 May 2017 10:07
#761409
No eBay APP ID and/or Cert ID defined in Kunena configurationGood choice ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
Re: Pistons
07 May 2017 11:41 - 07 May 2017 12:09
#761411
Fox wrote: With vernier caliper i can read bores at 69.9mm
So std i suppose?
Having the two over sized pistons means one could rebuild the motor twice and be able to have cylinder/piston clearance back to speck. This would require boring the bore. The std size can be used if there is no or little wear in the cylinder from the original factory bore.
Using a vernier caliper my guess is you have the reading at the top of the bore where there is no wear from the piston rings and covered with carbon.
The only true way to properly check the cylinder size is by using an inside diameter micrometer. These are expensive and not found at your local hardware store.
Is this a good deal, meaning your ebay piston rings.....not trying to be difficult but just replacing the rings is a crapshoot. It may or may not solve your problem.
Blue 1975 Z1B
Red 2009 Concours 14
Last edit: 07 May 2017 12:09 by Z1Driver.
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: Pistons
07 May 2017 19:42
#761433
This all depends on what you're planning to do. If you had good compression and you're replacing the rings while the engine is apart for something else, then yes, go for standard.
If you have low compression or just high mileage, just replacing the rings may not do much at all if the bore is worn or damaged. I would strongly recommend taking the block to an engine builder and ask them to check it, and re-bore it if it's worn. Because if you just replace the rings and the bore is worn, you've gone through all that effort for nothing. If the bores are fine then pay the engine builder for his time and a hone, which will be cheap.
1981 KZ750 LTD
The following user(s) said Thank You: GPz550D1, Fox
  • Z1Driver
  • Z1Driver's Avatar
Re: Pistons
07 May 2017 20:47
#761435
I agree with Irish.
Blue 1975 Z1B
  • KZB2 650
  • KZB2 650's Avatar
Re: Pistons
08 May 2017 06:39
#761445
And if you go all the way Wiseco's 1075 or 1105 kit sure would be nice.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • Fox
Re: Pistons
08 May 2017 08:50
#761462
The compression is good.
The problem is a blue smoke from exausts and a too much oil consomation.
For the moment I replace the piston rings. i find that 1st owner put all the 2nd rings upside down...
If you have other idea for this blue smoke problem...
Regards
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
