Recommended Headwork for Slightly Overbored GPZ110
  • diego092409
  • diego092409's Avatar Topic Author
05 Jan 2017 06:17
#751445
I am pulling the trigger on buying the oversized pistons for my 1982 KZ1100 B2. I am going for either 74 or 75 mm 10.25:1 wiseco pistons. I am doing it more for the high comp than punching out the engine.
What I am wondering is can I get by with just leaving the stock size valves in place or am I wasting my money not upping the valve size at this time? I really would like this to be the last time I take the head of the bike.
My goal is a solid reliable running bike that is moderately quick, not going out to hustle sport bikes, just a nice sounding streetable cruiser, potentially teaching motorcycle safety classes with it.
1982 KZ1100 B2 - 'Old Red' kzrider.com/forum/11-projects/601185-gpz-1100-resto-mod-old-red
2015 BMW K1600GT
2017 KTM 690 Enduro R
2018 Kymco Spade (wife's)
  • TexasKZ
  • TexasKZ's Avatar
Re: Recommended Headwork for Slightly Overbored GPZ110
05 Jan 2017 06:30
#751447
In my ignorant, ameture opinion, with stock cams and a small displacement increase, there is no need to increase the size of the valves. I think the only time you would be loosing anything with the factory valves is very near redline, and I take from your comments that low and midrange will be much more important to you.
  • diego092409
05 Jan 2017 06:46
#751450
The cams will be updated someday but in reality, would be timing it with a couple degrees of advance for bottom end more than redlining it..
If I want to go 90 MPH for hours on end, I have the beemer for that. This is just going to be my around town bike.
2015 BMW K1600GT
  • TexasKZ
  • TexasKZ's Avatar
05 Jan 2017 07:22
#751453
  • jertho
  • jertho's Avatar
05 Jan 2017 08:54
#751456
I agree with Texas KZ. Just do a good valve job and the bigger piston kit and I believe you will be quite pleased with the outcome. Back in the 70,s I had a 76 900LTD that I put an MTD 1170 kit in with no head work and had a nice ridable street machine. Of course to go that big required boring out the cases. I also had the crank welded befor it went back together.
Jerry
1978 kz750 twin
  • zed1015
  • zed1015's Avatar
05 Jan 2017 09:19
#751462
Having the head flowed would be best to get the full advantage of the capacity increase.
  • zukdave
  • zukdave's Avatar
05 Jan 2017 15:54
#751490
For a nice around town/bar hopper motor I'd do the 74 mm pistons, a good valve job, stock cams
a 4-1 pipe and a good ign.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • GPzEric
  • GPzEric's Avatar
05 Jan 2017 18:17
#751509
On my B2 I did a valve job, and it wasn't until I was forced to that I went with the '84 Head, which has bigger valves, and more flow, and it made a noticeable difference - especially from 6500 rpm's and up.
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
05 Jan 2017 21:08
#751518
GPzEric wrote: On my B2 I did a valve job, and it wasn't until I was forced to that I went with the '84 Head, which has bigger valves, and more flow, and it made a noticeable difference - especially from 6500 rpm's and up.
+1 ... :woohoo:
1982 KZ1100-A2/1170 sleeper 😀
  • DFIGPZ
  • DFIGPZ's Avatar
08 Jan 2017 06:45
#751678
Porting factory head a much better option than using 83 /84 GPZ head .
1984 750 Turbo
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
08 Jan 2017 08:06
#751685
DFIGPZ wrote: Porting factory head a much better option than using 83 /84 GPZ head .
:blink: Please explain.
  • 750 R1
  • 750 R1's Avatar
08 Jan 2017 13:26
#751716
zed1015 wrote: Having the head flowed would be best to get the full advantage of the capacity increase.
BINGO, the single biggest performance increase for most old Japanese bikes is in cleaning up the ports, its amazing just how much power can be gained by well ported head..
