Recommended Headwork for Slightly Overbored GPZ110
  • TexasKZ
  • TexasKZ's Avatar
Re: Recommended Headwork for Slightly Overbored GPZ110
08 Jan 2017 13:46
#751724
diego092409 wrote: My goal is a solid reliable running bike that is moderately quick, not going out to hustle sport bikes, just a nice sounding streetable cruiser, potentially teaching motorcycle safety classes with it.
Can somebody clearly demonstrate that a ported head will be better than a stock GPz head for achieving the op's goal?
  • 750 R1
  • 750 R1's Avatar
09 Jan 2017 13:51
#751802
Surely you're not suggesting a ported head won't increase power..? :P A ported head, even a cleaned up head {ports of course}, will make more power, as will a number of other mods. Its just my experience that there's usually more power locked up in the stock heads of these old bikes than any other single modification..... ;)
  • zukdave
  • zukdave's Avatar
09 Jan 2017 20:12 - 09 Jan 2017 20:14
#751831
But if you start with the best factory head then do the port work :ohmy:
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 09 Jan 2017 20:14 by zukdave.
  • TexasKZ
  • TexasKZ's Avatar
09 Jan 2017 23:14
#751840
Of course a properly ported head will make more power, especially near the top of the rpm range, but I really don't think that is what the op wants. Please look at the quote.
  • TexasKZ
  • TexasKZ's Avatar
09 Jan 2017 23:15
#751841
Moderators----
How did my reply to the 1981 750E thread end up here?
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
10 Jan 2017 06:04
#751853
TexasKZ wrote: Moderators----
Moved it. Took me a few tries , but moved it :whistle:
Dave B) B) B)
The following user(s) said Thank You: TexasKZ
  • 750 R1
  • 750 R1's Avatar
10 Jan 2017 14:24
#751908
TexasKZ wrote: Of course a properly ported head will make more power, especially near the top of the rpm range, but I really don't think that is what the op wants. Please look at the quote.
Please look at the tongue sticking out smiley Texas {having some fun}, also look at the thread title {serious :laugh: } .... If the headwork isn't too extreme there will be improvements right across the rev range, just use the smaller stock valves and don't go huge on the cam........ ;)
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
10 Jan 2017 18:41
#751917
Interesting especially the link to the Bathtub head. As some of you might remember I just put together my Frankinbike (GPZ1100B with all my spare bits).
I had no intention of making a rocketship but ended up with one. The porting without doubt was one of the reasons and the other was the 83 GPZ1100A cams. I was amazed at the low/ top end power it puts out when ALL else is stock (I had a J model head, pistons STD, Valves STD etc). It might not compare to some big bore bikes but it won't be embarrassed either.
I must add the bike weights 215kg wet (half tank of fuel).
So my recommendation, porting at least and decent cams for street use (not racing cams) BUT don't forget change the valve springs if they are old.
Also don't forget more power means a wilder ride unless other running mods are made (frame etc)
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
10 Jan 2017 19:06 - 10 Jan 2017 19:09
#751919
Bozo wrote: Interesting especially the link to the Bathtub head. As some of you might remember I just put together my Frankinbike (GPZ1100B with all my spare bits).
Thought I was reading about my own engine for a moment. :whistle: The exception being the ZN 1100 (bath tub) head, on which the valves were left stock too.
The head did have minimal factory porting originally done by Kawasaki, limited to the intake runners directly above the valves. I wonder what a quality minimal porting job on the head would do for the engine performance, or if it would even be worth having done for a street bike.
What would be the going-rate for a porting job on a J or GPz bath tub head, retaining the stock valves as well?
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 10 Jan 2017 19:09 by daveo.
  • Bozo
  • Bozo's Avatar
10 Jan 2017 23:35 - 11 Jan 2017 20:03
#751931
Daveo, I ported my GPZ head myself, I concentrated on the flow not so much making the port wider, I did not make them mirror shine, I purposely left them slightly rough. The valve seats were ported to the seat and both Intake and exhaust outputs were matched to what ever was bolted to them.
I run 36mm CV's from the ZRX (minor mods required), the response is incredible (its the pumpers). Some say these are too big but I dare anyone after riding this bike to criticize them (low and topend).
The cams haven't been dialed in and the way its going now, that can wait. At present I'm doing final touches to get good fuel economy without loosing power.
I have a fairly beat up 83 head in my shed and after reading this I have decided to remove the spiders and try to clean it up for the future
Edit: I stated a GPZ head porting I meant a Z1000J head which is fitted to Frankibike
Last edit: 11 Jan 2017 20:03 by Bozo. Reason: Added Note
  • DFIGPZ
  • DFIGPZ's Avatar
11 Jan 2017 16:32
#751982
Porting the stock 'J' Model head is a better option than the 83/84 Head Lower Compression, Low port Velocity Why do you think 83 / 84 GPZ 1100 Had DFI ? poor low speed response Stock 83 /84 head flows approx 84-86 cfm porting a 'J" head to those numbers by a Competent Porter ! to the same numbers way better for carbed street engine .
1984 750 Turbo
  • zed1015
  • zed1015's Avatar
12 Jan 2017 04:00 - 12 Jan 2017 04:02
#751998
83/84 GPZ1100/Spectre etc bathtub style heads are actually higher comp ( smaller combustion chamber volume) than the earlier 'J' heads.
Last edit: 12 Jan 2017 04:02 by zed1015.
