Probably a really stupid question
- missionkz
Re: Probably a really stupid question
19 Dec 2016 18:23 - 19 Dec 2016 18:24Very good... use a 280..Bama704 wrote: I fixed my edit, the 258 is supposed to read 285
002" is a little tight and I'd probably open those one size too but I also would not be scared to just replace that one 285 with a 280, drain the oil, change the filter, pour in high quality oil (at least 10-40 wet clutch rated oil) and drive it as is for a while but check again in a month or so.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 19 Dec 2016 18:24 by missionkz.
- 80B4
20 Dec 2016 07:34
I always make a map of the shims that end up in my bikes after I adjust them It saves saves a lot of time at the next clearance check
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- missionkz
20 Dec 2016 11:26Yeah me too... I have lots of little tear sheets in the garage with 8 circles, I or E and numbers in them!80B4 wrote: I always make a map of the shims that end up in my bikes after I adjust them It saves saves a lot of time at the next clearance check
If I could only remember to write the date on them every time! LOL
Bruce
1977 KZ1000A1
1977 KZ1000A1
21 Dec 2016 13:15missionkz wrote:Very good... use a 280..Bama704 wrote: I fixed my edit, the 258 is supposed to read 285
Don't want to hijack this thread but "wet clutch rated oil". Never heard the term before. Can you elaborate on that. I was just about to change the in my '76 A4
- KZB2 650
21 Dec 2016 13:53 - 21 Dec 2016 13:54
Mikaw...... Mission means a motorcycle oil or one that has a Jaso rating like Rotella for a wet clutch.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 21 Dec 2016 13:54 by KZB2 650.
21 Dec 2016 14:13Thank you. Just saved me from a potential serious mistake.KZB2 650 wrote: Mikaw...... Mission means a motorcycle oil or one that has a Jaso rating like Rotella for a wet clutch.
- missionkz
21 Dec 2016 18:06 - 21 Dec 2016 18:07JASO MA ratings.Mikaw wrote:missionkz wrote:Very good... use a 280..Bama704 wrote: I fixed my edit, the 258 is supposed to read 285
I've been using Rottela T4 15-40 for a couple years now. Good stuff and inexpensive when buying it gallon bottle from places like Walmart... $15.00 or so. Sometimes on sale for $13.00 per gallon.
www.whitedogbikes.com/whitedogblog/choos...o-and-jaso-ma2-mean/
www.walmart.com/ip/Shell-Rotella-T-15W-4.../14958327#about-item
Bruce
1977 KZ1000A1
1977 KZ1000A1
Last edit: 21 Dec 2016 18:07 by missionkz.
21 Dec 2016 18:30
I was using Castrol GTX 20-50 and going through a Qt. of oil every 500 miles. Switched to Rotilla and the oil burning stopped. Good stuff.
- KZB2 650
21 Dec 2016 18:51
Since a lot of my riding is in cooler weather I might try the 5-40 Rotella synthetic (for quicker flow) after I use up the 10/40 Valvoline bike oil that's in it now.
1978 KZ650 b-2
21 Dec 2016 19:05
[/quote]JASO MA ratings.
www.walmart.com/ip/Shell-Rotella-T-15W-4.../14958327#about-item [/quote]
I found the same white dog bike site and read up on the JASO ratings. I stopped riding in late '80's so this is all new to me. MissionKz do you live in a warmer climate and that's why you went with the cold 15 rating. I'm in Michigan and we see the entire temperature range here so maybe better for me to stick with the 10/40 unless you like the 15/40 to help larger clearances on a older bike?
- missionkz
21 Dec 2016 21:19
I'm just 15 to 16 miles northeast of the city limits of Denver Colorado.
I'm from Detroit though and the winters here are about 20 degrees warmer most of the time. Rarely does it hit 100 here but plenty of 90 degree days. It was -15 just few days ago and 54 degrees the day before that!!
Bruce
1977 KZ1000A1
1977 KZ1000A1
- toolmaker
22 Dec 2016 05:51KZB2 650 wrote: Since a lot of my riding is in cooler weather I might try the 5-40 Rotella synthetic (for quicker flow) after I use up the 10/40 Valvoline bike oil that's in it now.
If I use anything lighter than 20-50 in my KZ900 the oil warning light stays on.
I live near Portland, Oregon and my rider is a '76 KZ900 I bought new. I'm also in the process of restoring another one and a '73 Z1.
