Engine Spec and Cam Timing
  • zed1015
  • zed1015's Avatar
Re: Engine Spec and Cam Timing
17 Oct 2016 11:49
#745442
JoHNY wrote: Cover won't actually bolt down with tension and if you force it you'll warp the cover. What's interesting is although I think it makes no odds is once tentioned it pulls both cams out but only very slightly
Seen plenty that have been fully bolted down with the tensioner in situ and it has quickly resulted in damaged tensioners and snapped cam chains also once on, the exhaust cam timing in relation to the crank is not affected. only the inlet cam which is slightly advanced towards it's intended timing figure.
The inlet cam timing is retarded by a few degrees until the cover is bolted on which is why the timing procedure is reliant on the pin count.
That is how Kawasaki designed it.
  • JoHNY
  • JoHNY's Avatar
17 Oct 2016 12:37
#745447
ah right, so the inlet cam advances by a degree or two to its correct position when tentioned, always wondered?
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Oct 2016 18:43
#745495
Will likely bust the guides.
