Ebay Cams- Did I buy scrap metal?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Ebay Cams- Did I buy scrap metal?
13 Aug 2016 19:57
#738593
The seller was hoping the buyer would use them at least until the time ran out. The measurements are off too. Tells me they are worn out as well.
  • TexasKZ
  • TexasKZ's Avatar
13 Aug 2016 22:21
#738600
Yes, I'm kidding. As far as I know, the only way to correct pitting on cam lobe is to hard weld and regrind. Hardly worth the expense in this case.
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
13 Aug 2016 22:58 - 13 Aug 2016 23:00
#738602
TexasKZ wrote: Yes, I'm kidding. As far as I know, the only way to correct pitting on cam lobe is to hard weld and regrind. Hardly worth the expense in this case.
Yes indeed - cams and pistons aren't usually worth spit if they are used. I wouldn't suggest paying more than 5% of new price on any used cams or pistons without seeing them in person first......
Carbs are nearly as bad - buying used you should at least half expect them to be junk.
And all used brake master cylinders over 10 years old = scrap bin filler material.
Last edit: 13 Aug 2016 23:00 by Kray-Z.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
13 Aug 2016 23:52
#738606
The biggest part of making America great again, would be that folks learn to be honest with one another. If we can't have that anymore, then any sincere effort to achieve that greatness will be vain.
1982 KZ1100-A2/1170 sleeper 😀
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Aug 2016 05:36
#738610
As I say, you can't spit without hitting a scammer. :dry:
