Ebay Cams- Did I buy scrap metal?
- nitrokeeb
08 Aug 2016 19:01
I bought a set of cams described as Cam Motion Z1/Z2. A little confusing as those are two different cams, but both are "drop ins", and I thought would nicely match my 900. Upon opening the package I did not find either Z1 or Z2 stamped anywhere. So I measured a few lobes to check the lift. Came up with .410 and .420 when measuring one lobe on each cam. That didn't seem right as the Cam Motion didn't seem to have a .410.
I also noticed some pitting on one intake lobe that had me concerned.
I know these cams are usually stamped on the end, but there are no markings to be found except for the casting marks. I tried measuring again today, and the first lobe I checked measured 1.100 at the base circle, and 1.500 tall. Well that matches the .400 lift of the Z1 grind. But the next two lobes I checked had a base circle closer to 1.085, while still being 1.500 tall. That explains the extra lift I measured earlier. if the lobes had worn down a full 15 thou, shouldn't they be shorter? I would think the tip of the lobe would wear more than the sides base circle. Is this normal tolerances for old aftermarket cams? Should I try and return them?
Attachment camcard.jpg not found
Attachment exhasutcam1.jpg not found
Attachment Exhasutcam2.jpg not found
Attachment Intake1.jpg not found
Attachment Intake2.jpg not found
Attachment intake3.jpg not found
Attachment lobe.jpg not found
1978 KZ1000B LTD w/KZ900 engine
Re: Ebay Cams- Did I buy scrap metal?
08 Aug 2016 19:05
Looks like rust pitting. How much?
- nitrokeeb
08 Aug 2016 19:11
It does seem like rust pitting. You can feel the texture with your fingers, but it doesn't catch a fingernail. Other than that, I"m not sure how to measure the depth of the pitting. It runs down both sides of the lobe.
08 Aug 2016 19:31
I'd return them not as described.
08 Aug 2016 19:34
I wouldn't run that cam. I'd return them and make the seller pay the return shipping.
- missionkz
08 Aug 2016 19:40
Those cams are junk.
If eBay, file claims ASAP.
Demand return shipping
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
08 Aug 2016 19:45
Who's the seller?
- nitrokeeb
08 Aug 2016 20:07
I requested a return. I will refrain from publicly defaming anyone until this is worked out. You can PM me if you are concerned about buying from this seller. It is a higher volume seller listing "dragbike" parts.
08 Aug 2016 20:14
I probably know already. Two come to mind. Been burned by both.
- DFIGPZ
09 Aug 2016 13:51
More Junk from OINK ????????
1984 750 Turbo
09 Aug 2016 14:42 - 09 Aug 2016 14:59
Last edit: 09 Aug 2016 14:59 by SWest.
- nitrokeeb
09 Aug 2016 15:18
Steve got it. Don't know what you win though. Set of trashed cams?
