- Thank you received: 10
Ebay Cams- Did I buy scrap metal?
- nitrokeeb
08 Aug 2016 19:01 #737923
by nitrokeeb
1978 KZ1000B LTD w/KZ900 engine
Ebay Cams- Did I buy scrap metal? was created by nitrokeeb
I bought a set of cams described as Cam Motion Z1/Z2. A little confusing as those are two different cams, but both are "drop ins", and I thought would nicely match my 900. Upon opening the package I did not find either Z1 or Z2 stamped anywhere. So I measured a few lobes to check the lift. Came up with .410 and .420 when measuring one lobe on each cam. That didn't seem right as the Cam Motion didn't seem to have a .410.
I also noticed some pitting on one intake lobe that had me concerned.
I know these cams are usually stamped on the end, but there are no markings to be found except for the casting marks. I tried measuring again today, and the first lobe I checked measured 1.100 at the base circle, and 1.500 tall. Well that matches the .400 lift of the Z1 grind. But the next two lobes I checked had a base circle closer to 1.085, while still being 1.500 tall. That explains the extra lift I measured earlier. if the lobes had worn down a full 15 thou, shouldn't they be shorter? I would think the tip of the lobe would wear more than the sides base circle. Is this normal tolerances for old aftermarket cams? Should I try and return them?
Attachment camcard.jpg not found
Attachment exhasutcam1.jpg not found
Attachment Exhasutcam2.jpg not found
Attachment Intake1.jpg not found
Attachment Intake2.jpg not found
Attachment intake3.jpg not found
Attachment lobe.jpg not found
- Thank you received: 2749
08 Aug 2016 19:05 #737925
by SWest
Replied by SWest on topic Ebay Cams- Did I buy scrap metal?
Looks like rust pitting. How much?
- nitrokeeb
08 Aug 2016 19:11 #737927
by nitrokeeb
Replied by nitrokeeb on topic Ebay Cams- Did I buy scrap metal?
It does seem like rust pitting. You can feel the texture with your fingers, but it doesn't catch a fingernail. Other than that, I"m not sure how to measure the depth of the pitting. It runs down both sides of the lobe.
08 Aug 2016 19:31 #737933
by SWest
I'd return them not as described.
- Thank you received: 2823
08 Aug 2016 19:34 #737934
by Nessism
Replied by Nessism on topic Ebay Cams- Did I buy scrap metal?
I wouldn't run that cam. I'd return them and make the seller pay the return shipping.
- missionkz
08 Aug 2016 19:40 #737935
by missionkz
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Replied by missionkz on topic Ebay Cams- Did I buy scrap metal?
Those cams are junk.
If eBay, file claims ASAP.
Demand return shipping
Bruce
1977 KZ1000A1
08 Aug 2016 19:45 #737936
by SWest
Who's the seller?
- nitrokeeb
08 Aug 2016 20:07 #737939
by nitrokeeb
I requested a return. I will refrain from publicly defaming anyone until this is worked out. You can PM me if you are concerned about buying from this seller. It is a higher volume seller listing "dragbike" parts.
08 Aug 2016 20:14 #737940
by SWest
I probably know already. Two come to mind. Been burned by both.
- DFIGPZ
- Thank you received: 122
09 Aug 2016 13:51 #738022
by DFIGPZ
1984 750 Turbo
Replied by DFIGPZ on topic Ebay Cams- Did I buy scrap metal?
More Junk from OINK ????????
1984 750 Turbo
09 Aug 2016 14:42 - 09 Aug 2016 14:59 #738024
by SWest
Last edit: 09 Aug 2016 14:59 by SWest.
- nitrokeeb
09 Aug 2016 15:18 #738025
by nitrokeeb
Steve got it. Don't know what you win though. Set of trashed cams?
