Top end tear down?
- Defend132
- Thank you received: 2234
- Thank you received: 2749
- Defend132
- Defend132
- Thank you received: 2829
Defend132 wrote: Will try a leak down test, Where do you get a tool for that? Yeah the 400 miles were in the last 2 years ( more time working on bike than riding) It sat all winter in my unheated garage. Thanks for reply
Check out the free tool loaner programs at Auto Zone, Advance Auto, etc. to see which store can get the leak down test tool. You put down a deposit equal to the cost of the tool, use the tool for a couple days, and then return it for a full refund. I have used the Auto Zone program before for a tool I knew I would only use once in my lifetime. No muss / no fuss. Ed
- Defend132
- Tyrell Corp
- Thank you received: 261
Your rings may be stuck if unused for a while, one pot on my 750 was badly down on compression, within a few hundred miles it fixed itself. Don't be scared to thrash it a bit, particularly on the downchanges. (engine braking gives the rings a workout as they are working in the opposite direction) You could even pour some carb cleaner into the pots.
I'd try to eliminate the possibility of an ignition misfire, new HT leads and non resistor caps plus a check over of the ignition primary wiring, also lube the advancer.
If the motor was smoking badly, oil fouled plugs and guzzling oil it may be terminal, but you might also be able to save it, even if just for a bit longer. Most of my bikes are 40-50k miles, these motors are very durable.
- Defend132
Defend132 wrote: Would leaky valve seals cause the plug to foul(wet) reducing spark then causing sputtering?It is burning oil as well. What parts should I replace if i do a job like this?Thanks for the reply
Yes, leaky valve stem seals will allow oil to be drawn around the intake valve stems into the intake port and combustion chamber.
The only parts you will likely need are the gaskets(head, cam cover), end plugs, and any o-rings your model may have. You nan look at the parts fische at Kawasaki.com or Partzilla. Be sure that the valve stem seals are made of Viton. Genuine Kawasaki gaskets are genearally best, as many aftermarket ones are junk.
