Top end tear down?
Re: Top end tear down?
08 Jul 2016 19:30
When I was burning oil I had to down one step on the pilots.
- Nebr_Rex
10 Jul 2016 06:12Defend132 wrote: The main jet is 117.5 and the pilot is 17.5. the needle is on notch 3.
You are in the neighborhood.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Defend132
13 Jul 2016 17:54 - 13 Jul 2016 18:24
So I should go up to a 120 main and 20 pilot jet? I also cleaned out the tank and put new gas filters in. Put some carb cleaner in the number 1 cylinder and let it sit a couple of days. It seems to run better but it still has a small hesitation and the number 1 spark plug is fouled with dry soot not wet. Do you think the carbs were not synced properly? Would that cause just one plug to be fouled?
Last edit: 13 Jul 2016 18:24 by Defend132.
13 Jul 2016 18:34
Pics of plugs?
- missionkz
13 Jul 2016 19:05
In this heat, I dropped pilot jets one size down from 20 to 17.5 and was never satisfied with 112.5 to 115 so I moved up to 117.5 mains.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- Defend132
13 Jul 2016 19:08
First pic is cylinder on the left if you were sitting on the bike. Left to right.
13 Jul 2016 20:20
Rich and #4 looks fuel fouled.
- Defend132
14 Jul 2016 04:37 - 14 Jul 2016 04:58
Any ideas on the cause?Lower float height again? Points adjusted? Sync carbs again? Could it be that the carbs were not synced properly? All the plugs were fuel fouled before the sync. now only one is.
Last edit: 14 Jul 2016 04:58 by Defend132.
14 Jul 2016 05:52
Check the spark plug HT connection on #4.
- Defend132
14 Jul 2016 08:11
Spark plug wires. You can nip 1/4" off each end to make a better connection. Also the plug caps might be shot.
- Defend132
