!981 KZ650 H1
  • rrsmsw9999
  • rrsmsw9999's Avatar
Re: !981 KZ650 H1
17 Jun 2016 08:54
#731755
It is a simple H shape ended small wrench. just about any spoke wrench for a motorcycle will work, the rim parts are all metric. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • LuisCab
  • LuisCab's Avatar Topic Author
Re: !981 KZ650 H1
19 Jun 2016 06:45
#731977
Found one thanks for the help guys. I promise this is my last question...Do any of you know the specs on the exhaust I took (2003 KAWASAKI ZR7S ZR750 EXHAUST). Pretty sure me 1-1/2 inch pipe doesn't fit on it (too small), so looking a a new one (yayyy) to make it fit on the new exhaust system, but I can't seem to find the hole size for the pipe..
Thanks.
  • GPzMOD750
  • GPzMOD750's Avatar
Re: !981 KZ650 H1
19 Jun 2016 07:10
#731980
If your asking for slip on size I'm I think it's 2 1/4" iirc. I'm pretty sure that's the size of the Kerker I have on there. It was a little loose so I wrapped the end of the pipe with aluminum muffler repair tape to act as a bushing.
The following user(s) said Thank You: LuisCab
  • LuisCab
Re: !981 KZ650 H1
24 Jun 2016 10:43
#732663
So I received the new pipes yeahh!!! Quick q, how tight do I have to put them on the engine? When I took the old ones out, the bolts were pretty easy to undo but not sure if it was done right. Now I put them like this (see picture). I'll cut the pipe and weld it shorter obviously!
Thanks
  • Nessism
  • Nessism's Avatar
Re: !981 KZ650 H1
24 Jun 2016 11:36
#732669
Did you install new copper crush washers at the exhaust ports? If so, you must tighten the nuts enough to pull the pipes in snug to the port and compress the crush washers. Once you get some crush, assuring no exhaust leaks occur, you don't need to tighten any further.
  • LuisCab
Re: !981 KZ650 H1
27 Jun 2016 07:37
#733026
Hi,
Yes I did. Everything seems good. Just that since I changed the pipes, there is a stronger smell of gasoline. Also, I changed the jets a a month ago for some DynoJet stage 3 (because of the cone filters I have on the carbs) and since than, I'm doing like 18 mpg... Basically a fuel tank gives me for 130 km (I know because I got caught once and stalled on the highway without gas ^^ plus I have no fuel sensor light). Do you guys know up to what bigger size of a gas tank?
Thanks
  • LuisCab
Re: !981 KZ650 H1
24 Jul 2016 17:52
#736092
Hi guys, back again! Bike is up and running (thanks for all the help with the pipes :D looks amazing) but I seem that have a recurrent problem. I can leave the bike off for a couple of days and start it no problem. I try to start it the next day, doesn't shoot and the battery drops voltage pretty quick. Check the voltage on it before starting it, was at 12.34(V). Should be enough to fire specially that the day before I started it. Old bike so no electrical stuff staying on once the bike is off. Charged the battery today put it on the bike, bike started and battery seemed to charge while the RPM's were over 2k. Based on this information I can discard that the stator is still working properly or am I wrong?
Any ideas ? Thanks.
  • Nessism
  • Nessism's Avatar
Re: !981 KZ650 H1
24 Jul 2016 17:54
#736094
LuisCab wrote: Hi guys, back again! Bike is up and running (thanks for all the help with the pipes :D looks amazing) but I seem that have a recurrent problem. I can leave the bike off for a couple of days and start it no problem. I try to start it the next day, doesn't shoot and the battery drops voltage pretty quick. Check the voltage on it before starting it, was at 12.34(V). Should be enough to fire specially that the day before I started it. Old bike so no electrical stuff staying on once the bike is off. Charged the battery today put it on the bike, bike started and battery seemed to charge while the RPM's were over 2k. Based on this information I can discard that the stator is still working properly or am I wrong?
Any ideas ? Thanks.
What is your charging voltage at 5000 rpm?
