Z1 vs Z900 vs Z1000 Alternator rotor
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Z1 vs Z900 vs Z1000 Alternator rotor
08 Apr 2016 20:19
#719980
I would have used the key.
  • zed1015
  • zed1015's Avatar
09 Apr 2016 00:53
#720012
You must fit the woodruff key, especially with the decreased contact area of the scored taper.
The 8mm bolt on its own isn't enough to stop the rotor spinning loose and increasing the torque will cause the bolt to shear.
This is why they increased the bolt size to 10mm and increased the torque when they stopped using a key.
  • Bozo
  • Bozo's Avatar Topic Author
  • Ride it like u stole it
09 Apr 2016 03:19 - 09 Apr 2016 07:49
#720017
Ok. I'll fit the key before riding
Would you use more than the 18Ft/lb torque on the rotor bolt?? . Keep in mind my bike does easily rev to the rev limiting of 10K rpm
Last edit: 09 Apr 2016 07:49 by Bozo.
  • Bozo
09 Apr 2016 15:50
#720087
Bozo wrote: Ok. I'll fit the key before riding
Bump, Zed/Steve, see question above
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Apr 2016 16:17
#720088
That's what the book says. I just do it by hand. I had a problem with the rotor coming loose so I used blue lock tight on the taper. The rotor was coming apart later and I had to heat it up with a torch to get it off. If yours is in good shape and fits the taper well, it should stay on. Just use lock tight on the bolt.
  • zed1015
  • zed1015's Avatar
10 Apr 2016 01:36
#720145
Just go with the std torque setting and Loctite on the bolt threads only.
Any more torque is just risking stretching the bolt and having it fail.
The rpm's aren't really the issue, it's the force on rapid acceleration that shears the fit between the rotor and crank.
My Supercharged Z1000A revs like a 2 stroke and will hit 12k if I let it, It too has a 900 crank and has done 1000's of miles with no problem.
  • Bozo
10 Apr 2016 01:46
#720146
I did as suggested, I also checked the fitting with the wider rubber washer, it is 0.7mm thicker which is a fair bit, and it did push against the rotor hard, so that might've caused the rotor not to tighten on the taper properly. Anyway I'll rechecked this unit (assuming it doesn't rattle beforehand) in a month just to be safe.
