- Thank you received: 2
Z1R turbo head choices?
- mrdatsunturbo
- mrturbo Norway
So i need another head for my 1200cc engine build.what is the best choice for me?
J head with cam tower or a early GPZ head?
Thanks again and i was out riding in Norway today Cold but very nice.pictures was to big today??
- zed1015
- Thank you received: 1554
Being forced induction the smaller runners won't affect cylinder filling like it would on normally aspirated.
We run a 900 head on the Orient Express turbo and that produces over 230hp with 8.2 quarter at 165 mph.
- mrdatsunturbo
- mrturbo Norway
I will phone a owner of a Running J engine and take a look under the cover. Thanks a lot from me again.
- zed1015
It's a common verbal abbreviation for "Gee Pee Zed" over here in Englandmrdatsunturbo wrote: OK early geep head Hmmm never heard that name before :laugh:
- PLUMMEN
- Thank you received: 104
For a turbo motor Id worry more about the exhuast side than the intake.
- mrdatsunturbo
- mrturbo Norway
It is very fast as it is now, but when doing a overhaul ,always fun to try to make it better.
I have been like that since start driving turbo cars.
- PaintWorkz
It is never to late to go start drag racing!
If you are crazy enough to twist up a turbo Z1R on the street....making a pass down the drag strip would be a lot more sane.
www.paintworkz.com
84 Gpz900 street
77 KZ 1325 Turbo Dragbike project
79 CBX Pro Stock projects (2)
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
- missionkz
oopszed1015 wrote: For a 1200 turbo you will get away with the early heads if you want although a 'J' or early geep head will work well too.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- missionkz
wow. 230hp at what RPM? With stock chamber cc's, valves and no porting?zed1015 wrote: For a 1200 turbo you will get away with the early heads if you want although a 'J' or early geep head will work well too.
Bruce
1977 KZ1000A1
- zed1015
I forget the exact RPM for max power and the Dyno sheets are at the shop though i'm sure I mentioned in the build thread I think.
Rev limiter is set at 10.5k for the track though but haven't hit it in 4th 'n' 5th yet.
1075cc MTC pistons.
Stock combustion chambers.
1mm o/s valves.
Minimal clean up on ports, inlet matched to plenum and exhaust polished .
Header diameter = 36mm.
It's pretty much what you would run on the road except for the Megacycle turbo race cams.
My road turbo Z1R is the same spec (right down to the F/F Rajay) except for Unitrack cams to take the edge off.
- mrdatsunturbo
- mrturbo Norway
There was a dragracer parting out his KZ900 turbo dragbike and i buyed his head from his running 900.
It is GPZ ?? head i need to do some search if not someone see what year and type it is.
I got cams not shure about type but it is more lift than on my Norris turbo cams,,ape cam sprocket
overall it looks good,a homemade cam Chain Tower, copper oilpipe to the head so there is some work to do.
APE cam Chain Conversion Tower ,will this fit?
Need to do a tachometer drive , So please ladies and gentlemen tell me good and bad News about my New toy
I took a Picture of my old driving gear back from early 80
Attachment IMG_0218.JPG not found
Attachment IMG_0214.JPG not found
Attachment IMG_0221.JPG not found
Attachment IMG_0213.JPG not found
- mrdatsunturbo
- mrturbo Norway
33mm intake port and valves 38.5
30mm exhaust and valves 32.5
