Z1R turbo head choices?
- mrdatsunturbo
- mrturbo Norway
02 Apr 2016 08:07
I looked at the head before delivery to the machinist and there is also a lot of damaged on treads and also two cam caps broken.This was also in bitses and pieces from PO
So i need another head for my 1200cc engine build.what is the best choice for me?
J head with cam tower or a early GPZ head?
Thanks again and i was out riding in Norway today Cold but very nice.pictures was to big today??
- zed1015
Re: Z1R turbo head choices?
02 Apr 2016 08:15
For a 1200 turbo you will get away with the early heads if you want although a 'J' or early geep head will work well too.
Being forced induction the smaller runners won't affect cylinder filling like it would on normally aspirated.
We run a 900 head on the Orient Express turbo and that produces over 230hp with 8.2 quarter at 165 mph.
The following user(s) said Thank You: PLUMMEN
- mrdatsunturbo
- mrturbo Norway
02 Apr 2016 09:28
OK early geep head Hmmm never heard that name before :laugh:
I will phone a owner of a Running J engine and take a look under the cover. Thanks a lot from me again.
- zed1015
02 Apr 2016 11:31It's a common verbal abbreviation for "Gee Pee Zed" over here in Englandmrdatsunturbo wrote: OK early geep head Hmmm never heard that name before :laugh:
- PLUMMEN
02 Apr 2016 21:45
How is the bike going to be ridden,Street bike or track bike?
For a turbo motor Id worry more about the exhuast side than the intake.
- mrdatsunturbo
- mrturbo Norway
02 Apr 2016 23:00
This will be street i am to old to start drag racing now
It is very fast as it is now, but when doing a overhaul ,always fun to try to make it better.
I have been like that since start driving turbo cars.
- PaintWorkz
03 Apr 2016 11:52
Turbo,
It is never to late to go start drag racing!
If you are crazy enough to twist up a turbo Z1R on the street....making a pass down the drag strip would be a lot more sane.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
- missionkz
03 Apr 2016 17:24 - 03 Apr 2016 17:27oopszed1015 wrote: For a 1200 turbo you will get away with the early heads if you want although a 'J' or early geep head will work well too.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 03 Apr 2016 17:27 by missionkz.
- missionkz
03 Apr 2016 17:25wow. 230hp at what RPM? With stock chamber cc's, valves and no porting?zed1015 wrote: For a 1200 turbo you will get away with the early heads if you want although a 'J' or early geep head will work well too.
Bruce
1977 KZ1000A1
1977 KZ1000A1
- zed1015
04 Apr 2016 01:14 - 04 Apr 2016 01:26missionkz wrote:wow. 230hp at what RPM? With stock chamber cc's, valves and no porting?zed1015 wrote: For a 1200 turbo you will get away with the early heads if you want although a 'J' or early geep head will work well too.
I forget the exact RPM for max power and the Dyno sheets are at the shop though i'm sure I mentioned in the build thread I think.
Rev limiter is set at 10.5k for the track though but haven't hit it in 4th 'n' 5th yet.
1075cc MTC pistons.
Stock combustion chambers.
1mm o/s valves.
Minimal clean up on ports, inlet matched to plenum and exhaust polished .
Header diameter = 36mm.
It's pretty much what you would run on the road except for the Megacycle turbo race cams.
My road turbo Z1R is the same spec (right down to the F/F Rajay) except for Unitrack cams to take the edge off.
Last edit: 04 Apr 2016 01:26 by zed1015.
The following user(s) said Thank You: PLUMMEN, mrdatsunturbo
- mrdatsunturbo
- mrturbo Norway
04 Apr 2016 10:41
i was out for shopping today and dont tell me you cant use it?
There was a dragracer parting out his KZ900 turbo dragbike and i buyed his head from his running 900.
It is GPZ ?? head i need to do some search if not someone see what year and type it is.
I got cams not shure about type but it is more lift than on my Norris turbo cams,,ape cam sprocket
overall it looks good,a homemade cam Chain Tower, copper oilpipe to the head so there is some work to do.
APE cam Chain Conversion Tower ,will this fit?
Need to do a tachometer drive , So please ladies and gentlemen tell me good and bad News about my New toy
I took a Picture of my old driving gear back from early 80
Attachment IMG_0218.JPG not found
Attachment IMG_0214.JPG not found
Attachment IMG_0221.JPG not found
Attachment IMG_0213.JPG not found
- mrdatsunturbo
- mrturbo Norway
04 Apr 2016 12:11
port and valve sizes
33mm intake port and valves 38.5
30mm exhaust and valves 32.5
