valve fell ruined piston need help.
  • Gjason89
  • Gjason89's Avatar Topic Author
01 Apr 2016 07:18
#718664
so i have put a ton of time and money into this bike and mad that now i back at square one. i have with me a 1982 kawasaki ltd 550 was all cleaned and had it running after a minor restoration. but then out of prison number three i saw from the exhaust pipe that oil was spitting out so i turned it off and saw that there was a huge hole in the piston a missing valve and the cylinder walls are a bit scratched up. can anyone point me PLEASE in the right direction on what to do and the parts . i plan on removing the engine from frame AGAIN so that i can work on it . :(
  • car5car
  • car5car's Avatar
  • Banned
  • Banned
Re: valve fell ruined piston need help.
01 Apr 2016 07:26
#718667
Parts replacement depends on damage.
post pictures of head, cylinder, piston
96 Yamaha Royal Star
82 Yamaha Virago 920
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Apr 2016 07:37
#718670
You'll need to find some barrels and pistons on eBay and hopefully the head wasn't damaged too much.
Pics?
  • Gjason89
01 Apr 2016 07:40
#718671
I had the pictures but lost them and put the engine back together so it wouldn't get rusted but I will definitely get it taken apart this weekend and post pictures of everywhere that I can . I'm afraid that all the metal and the missing valve is all in chunks at the bottom of the engine . Thanks for the quick reply I will get the engine taken apart today so that I can post the pictures thanks once again !!!
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Apr 2016 07:46
#718672
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Apr 2016 07:49
#718673
No eBay APP ID and/or Cert ID defined in Kunena configurationIf you were to get the head it would be wise to replace the valve guide seals too.
  • rrsmsw9999
  • rrsmsw9999's Avatar
01 Apr 2016 08:13
#718678
For that probable part list and effort you should consider a replacement motor 200-600$ bucks. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
The following user(s) said Thank You: PLUMMEN
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Apr 2016 08:18
#718680
That would be good. Always good to have spare parts. B)
  • car5car
  • car5car's Avatar
  • Banned
  • Banned
02 Apr 2016 04:19
#718820
Long time ago I forgot to tighten camshaft sprocket bolt... :(
  • Gjason89
04 Apr 2016 08:07
#719188
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationSo I've been searching for a good jug and set of piston. I figure I also need a new rod for the one that got banged up with the valve that fell. I don't think that I need a new head simply help finding a replacement valves for the two that messed up . can some one tell me what will work and were I can find the valves and the piston rod.
And will these rods fit. I only need one
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Apr 2016 09:11
#719201
When I dropped a valve in my 350, I had to get a new valve, guide seals and a oversize piston. I rode it home (I was 19) all hell was breaking loose in there. :lol: It didn't damage the rod and they had roller bearing cranks. I carried my old valve as a good luck charm. It looked like a marble. :dry:
Did you check out the links I put up?
  • Gjason89
04 Apr 2016 16:51
#719272
:dry: so I got pictures again of the damage it appears the valve from the exhaust broke off and banged he'll in piston number three . Does anyone have the spare parts I need what should I do it is a must to be repaired I will not let it sit and collect dust. Especially after all work I've done already .
