valve fell ruined piston need help.
01 Apr 2016 07:18 #718664 by Gjason89
valve fell ruined piston need help. was created by Gjason89
so i have put a ton of time and money into this bike and mad that now i back at square one. i have with me a 1982 kawasaki ltd 550 was all cleaned and had it running after a minor restoration. but then out of prison number three i saw from the exhaust pipe that oil was spitting out so i turned it off and saw that there was a huge hole in the piston a missing valve and the cylinder walls are a bit scratched up. can anyone point me PLEASE in the right direction on what to do and the parts . i plan on removing the engine from frame AGAIN so that i can work on it . :(
01 Apr 2016 07:26 #718667 by car5car
Replied by car5car on topic valve fell ruined piston need help.
Parts replacement depends on damage.
post pictures of head, cylinder, piston
96 Yamaha Royal Star
82 Yamaha Virago 920
  • SWest
  • 10 22 2014
01 Apr 2016 07:37 #718670 by SWest
Replied by SWest on topic valve fell ruined piston need help.
You'll need to find some barrels and pistons on eBay and hopefully the head wasn't damaged too much.
Pics?
01 Apr 2016 07:40 #718671 by Gjason89
Replied by Gjason89 on topic valve fell ruined piston need help.
I had the pictures but lost them and put the engine back together so it wouldn't get rusted but I will definitely get it taken apart this weekend and post pictures of everywhere that I can . I'm afraid that all the metal and the missing valve is all in chunks at the bottom of the engine . Thanks for the quick reply I will get the engine taken apart today so that I can post the pictures thanks once again !!!
  • SWest
  • 10 22 2014
01 Apr 2016 07:46 #718672 by SWest
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • SWest
  • 10 22 2014
01 Apr 2016 07:49 #718673 by SWest
No eBay APP ID and/or Cert ID defined in Kunena configurationIf you were to get the head it would be wise to replace the valve guide seals too.
01 Apr 2016 08:13 #718678 by rrsmsw9999
Replied by rrsmsw9999 on topic valve fell ruined piston need help.
For that probable part list and effort you should consider a replacement motor 200-600$ bucks. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
The following user(s) said Thank You: PLUMMEN
  • SWest
  • 10 22 2014
01 Apr 2016 08:18 #718680 by SWest
That would be good. Always good to have spare parts. B)
02 Apr 2016 04:19 #718820 by car5car
Long time ago I forgot to tighten camshaft sprocket bolt... :(
04 Apr 2016 08:07 #719188 by Gjason89
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationSo I've been searching for a good jug and set of piston. I figure I also need a new rod for the one that got banged up with the valve that fell. I don't think that I need a new head simply help finding a replacement valves for the two that messed up . can some one tell me what will work and were I can find the valves and the piston rod.
And will these rods fit. I only need one
  • SWest
  • 10 22 2014
04 Apr 2016 09:11 #719201 by SWest
When I dropped a valve in my 350, I had to get a new valve, guide seals and a oversize piston. I rode it home (I was 19) all hell was breaking loose in there. :lol: It didn't damage the rod and they had roller bearing cranks. I carried my old valve as a good luck charm. It looked like a marble. :dry:
Did you check out the links I put up?
04 Apr 2016 16:51 #719272 by Gjason89
:dry: so I got pictures again of the damage it appears the valve from the exhaust broke off and banged he'll in piston number three . Does anyone have the spare parts I need what should I do it is a must to be repaired I will not let it sit and collect dust. Especially after all work I've done already .
